Results 1 to 6 of 6
    Default Galaxy S4: 4.4.2 post upgrade issues
    After upgrading my s4 to 4.4.2 the device keeps hanging and i have to restart the device each time it hangs. I tried the factory reset but the problem happened again. Pleaae help!!!
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Default Re: 4.4.2 post upgrade issues
    Well, It looks like KitKat is filled with the bugs, there are many user's complaining new issues with the recent KitKat update some users say that they want to postpone the update I'd be better on with the JellyBean. And the user who have updated to the KitKat are now saying that they are facing a new issue which was working fine !!
  3. #3
    I have the exact same problem. i cant use my phone.
    yesterday i got lucky for some reason my phone got loaded upto the lock up screen and i quickly powered it off and then when i turned it back on my phone was working but this morning same thing happened but even if i turn my phone off it still hangs.
    cant understand why they release a bugged OS. Is there anyway to get back to an older OS version???
  4. #4
    Looking to recover anything I possibly can onto a phone that had that upgrade done to it. was told that a factory reset. wouldn't affect what was on the SIM card. but ALL contacts, pictures, calander is gone off the phone.
    Anyone got any solutions?
  5. #5
    troshs's Avatar
    Posts
    Global Posts
    974 Global Posts
    Default Re: Galaxy S4: 4.4.2 post upgrade issues
    Do you have GPS turned off? This seemed to be a problem with a lot of phones....not mine, I had to do a factory reset before upgrading. If its on, try turning it off for a few days and see what happens.
  6. #6
    Hello, I also upgrade to kitkat 4.4.2 some weeks back. and I am facing some bugs with the wifi and data connections being switched off by itself.
    I am not able to back up my phone contacts and apps as usual, because it says no SD card or unable to backup reset sd.
    Has someone been able to fix these bugs, please do let me know.
    Thanks
  1. Tab 3 Lite stuck on "Firmware upgrade encountered an issue."
    By themajod in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-21-2015, 10:17 AM
  2. Issue with all Golf GPS apps and Pebble watch!
    By FAiello in forum Pebble Smartwatches
    Last Post: 05-08-2014, 11:23 PM
  3. someone please help, major issues
    By DomProJr in forum T-Mobile Galaxy S3
    Last Post: 04-13-2014, 09:31 PM
  4. Connectivity issue.
    By Hooligans Rule in forum T-Mobile Galaxy S 4G
    Last Post: 04-07-2014, 12:43 PM
  5. Keyboard issues w/rotated screen
    By HeatherDP in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-03-2014, 03:38 PM
