1. k1fox's Avatar
    Quick question - Does the equalizer setting you set in the music app apply to the audio in the entire phone or just within the music app? For example, If I change the EQ setting will it also apply to youtube/internet videos or in a radio app?
    04-04-2014 12:26 PM
  2. Amir's Avatar
    If you applied equalizer settings in some player then the audio in player is affected and if you downloaded separate equalizer software then phone audio will be affected.
    Sent from my SM-N9005 using Tapatalk
    04-04-2014 12:52 PM
  1. Go launcher transfer settings
    By Gary Howe in forum Android Apps
    Last Post: 07-29-2015, 08:46 PM
  2. Set HDR as default camera mode
    By ksmith8000 in forum HTC One M7
    Last Post: 06-17-2014, 01:30 AM
  3. Replies: 8
    Last Post: 04-07-2014, 03:22 PM
  4. Contact Settings
    By rgp2130 in forum HTC One M7
    Last Post: 04-02-2014, 10:59 AM
  5. LG Optimus G Pro E988 - APN settings
    By shaleen55 in forum LG Optimus G Pro
    Last Post: 04-02-2014, 05:30 AM
