1. 1caiser's Avatar
    I've tried the battery trick, I've done factory reset, I've cleaned the motherboard, I've tried to root my phone (then unrooted and restocked firmware), but none of these fixes my WiFi which consistently refuses to turn on. Anything else I've missed, or just send it into Samsung?
    Please no saying "I have the same problem". That just makes it harder for other people to find a solution...
    Thanks.
    04-15-2014 05:36 PM
  2. buci1er's Avatar
    Take it back to the carrier that you purchased it from and have them replace it for you
    Sent from my SM-G900V using Tapatalk
    04-15-2014 05:38 PM
  3. buci1er's Avatar
    There's no reason you should be having those types of issues with a phone that new
    04-15-2014 05:39 PM
  4. Jared Dotson's Avatar
    the connection from the wifi chip to board goes bad probably because of heat issues, you can try reflowing with a heat gun. I tried that and it started working again for like 30 minutes, I'm gonna attempt to re ball it before buying another phone.
    02-13-2015 11:23 AM
  5. walidg's Avatar
    I am having both the voice dissapearing when dialling but not when using viber or whatsupp.. Also the wifi signal is 2/5 whnen the other samsun is 5/5
    I tried everything i every thing from clearing cache, resetting to factory default (that works but apparently once some apps updates it starts again). i am gong to uninstall one app at a time to see what happens.. but from my technical background, it is a T- mobile issue when the phone is used with a non t-mobile Sim......
    06-24-2015 10:00 AM
  1. Galaxy S5 SD card file moving issues
    By mujertins in forum Samsung Galaxy S5
    Last Post: 11-02-2015, 01:15 AM
  2. Galaxy S4 with KitKat - Bluetooth Keeps Disconnecting
    By TammOk in forum Sprint Samsung Galaxy S4
    Last Post: 09-11-2015, 03:52 PM
  3. s4 active water damage?
    By SofieCobain in forum Samsung Galaxy S4 Active
    Last Post: 06-17-2014, 09:55 AM
  4. HTC One M8 Quick Issues and Questions
    By silentandcliche in forum Google Play edition HTC One M8
    Last Post: 04-15-2014, 05:25 PM
