Results 1 to 20 of 20
    Lexicon7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy S4 draining battery even when phone is off
    I don't know what is going on with my phone. I had my galaxy s4 for about a year and it was working fine. I noticed the battery was draining faster than usual, so I brought a new one (not stock). The new one was charged up to 100 percent, I left it in the phone overnight and turned it off. I turned it back on the next morning the battery was at 38 percent. I sent that one back. I brought two new batteries, different brand again. One of the batteries did the same thing as the last one. Tonight I'm trying the next battery in my phone overnight, phone off again. I went to Radioshack and they don't have the stock battery, the guy said it could be the phone or the battery.
  2. #2
    troshs's Avatar
    Posts
    Global Posts
    983 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: S4 draining battery even when phone is off.
    Is the phone under warranty? If so get a replacement. This sounds like too much BS to put up with on a daily basis and is NOT normal.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  3. #3
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Lexicon7 View Post
    Welcome to Android Central
    Sounds like it's the phone, seeing as the new batteries didn't fix the issue. Could you post screenshots of your battery stats?
    Sent from my Galaxy S4 running SlimKat 4.4.2
    Lexicon7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have insurance on it so if this battery doesn't work out tonight I'm axing it and calling my phone company.
    Lexicon7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lexicon7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've done everything I could think of from turning off useless apps and the usual.
  7. #7
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Not seeing anything too unusual that could cause battery drain. Cell signal isn't great but doesn't explain such a big drain overnight. Fully charge up your phone and download GSam battery monitor, then use your phone normally and post your stats again tomorrow to see if the drain is still there.
    electricpete likes this.
  8. #8
    electricpete's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    +1 gsam
    Lexicon7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That is my battery on gsam.
  10. #10
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    That's the native battery stats report, not GSam. That screenshot doesn't show asuch info as GSam would, which is why I asked for it.
  11. Thread Author  Thread Author    #11
    Lexicon7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oh, okay. I didn't understand what you asking for hahaha, sorry.
  12. #12
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Click the button on the far left of that screen. Looks sort of like a vacuum cleaner. That'll show what apps are using your battery, and then post it again here
    Lexicon7 likes this.
  13. Thread Author  Thread Author    #13
    Lexicon7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  14. #14
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy S4 draining battery even when phone is off
    Here's mine for info. Percentages not much different than yours. Both your screen and your apps uses a lot in short time. Screen particularly. Do you have it on auto?
  15. Thread Author  Thread Author    #15
    Lexicon7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nope it's always at 30 percent or less. Could a corrupt sd card be doing this?
  16. #16
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    I doubt it. I'm not seeing anything inherently wrong with your usage, but you're not getting very good screen on time. I think the poor signal has a lot to do with it.
  17. Thread Author  Thread Author    #17
    Lexicon7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I see what you mean. This is annoying, I have Verizon. They are suppose to be good with signal. I guess I'll just deal with this phone. The insurance I have will just take this one and give me a refurbished one, I don't know if I want to run the risk of getting a crappier phone than what I have.
  18. #18
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    I also noticed that you have SmartStay on. If you're not using that, turn it off as well as any other "Smart" or "Air" gestures you don't need. Do you have GPS on?
  19. Thread Author  Thread Author    #19
    Lexicon7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No, the gps is off. That's really odd because in my notification bar smart stay is off, maybe I need to turn it off manually.
  20. #20
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    There are several "Smart" features so you might want to make sure they're all off.
  1. Galaxy S4 - SGH-M919 Wifi issue
    By 1caiser in forum Samsung Galaxy S4
    Last Post: 06-24-2015, 11:00 AM
  2. Battery temp too cold/sim card rejected?
    By HelpNeeded15042014 in forum Orange Samsung Galaxy S4
    Last Post: 06-29-2014, 06:13 PM
  3. S4 Android 4.3 - Handcent SMS app in error loop - I can't use phone
    By Christopher Houston in forum Samsung Galaxy S4
    Last Post: 04-17-2014, 07:47 AM
  4. Is this phone available or not?
    By jkrc717 in forum Sony Xperia Z2
    Last Post: 04-16-2014, 08:54 AM
  5. Latest gear manager on non samsung phones.
    By ray1204 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 04-15-2014, 07:28 PM
