1. Adam Eliav's Avatar
    My Galaxy S4 is acting weird when texting. When my phone screen is off my phone vibrates for a text message, but when the screen is on it acts as if it is on silent and does not vibrate. Is there any way to get it to vibrate when the phone screen is on? Thanks =)
    04-21-2014 12:25 AM
  2. Kelly Burby's Avatar
    Well, I this just seems weird to me what I was going to prefer you is going to the settings and enabling the vibration but as you've said that your phone is vibrating when the screen is off the so, i think the vibration is enabled, but I would say try going to the vibration setting and choose some different vibration type at the time of choosing the vibration your device will vibrate to confirm which vibration type you have choose. Once vibration is confirmed then switch off your device for at least 5min and then try restarting, you problem will get resolved.
    04-21-2014 04:52 AM
  3. metle_geek's Avatar
    The charge light doesn't even come on when the screen is on so I'm thinking it's turned off by the Kernel it figures you would notice it in the notification bar??? Have you tried turning off power saver mode??
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    04-22-2014 11:07 AM
  1. Problem Downloading Group Text Messages in Group Thread
    By Akadia Kachaochana in forum T-Mobile Samsung Galaxy S4
    Last Post: 04-26-2014, 07:14 PM
  2. Reception Problems?
    By rickydhami in forum HTC One M8
    Last Post: 04-22-2014, 04:38 PM
  3. video problems
    By 918tiger in forum HTC One M8
    Last Post: 04-21-2014, 04:34 AM
  4. Samsung Galaxy S4 Audio Problems When Switching Between Apps
    By mccormit095 in forum Samsung Galaxy S4
    Last Post: 04-20-2014, 06:13 PM
  5. Opera Browser For Android And Text Reflow
    By PsychDoc in forum Samsung Galaxy S5
    Last Post: 04-20-2014, 01:53 PM
