Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By tvouge
    Lucy Davies's Avatar
    Posts
    Global Posts
    640 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy S4: Where is my memory going?
    I updated to kit kat today & after the update I noticed I had about 4 new apps appear & my memory was 2.15GB which is fine. I haven't downloaded anything & now my memory is 2.24GB so what is using my memory? Is it coz I've opened the new apps & they have created files? I'm really stumped. Any help would be much appreciated.
  2. #2
    acplaya's Avatar
    Posts
    Global Posts
    7 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: where is my memory going?
    Cache most likely, download a cleaning app.
    Posts
    Global Posts
    640 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oh didn't think of that thanks. Any ideas of a good cleaning app?
  4. #4
    Tsepz_GP's Avatar
    Posts
    Global Posts
    1,099 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No need for a cleaning app, just go to:
    Settings -More tab -Storage -click on Cached Data then Ok and you're done.
    Posts
    Global Posts
    640 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Tsepz_GP View Post
    Thanks will do that. What happens after I clear the cache? Will the apps create it again when I open the app?
  6. #6
    Tsepz_GP's Avatar
    Posts
    Global Posts
    1,099 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Lucy Davies View Post
    Yep.
    They will indeed. I cleared mine a month ago, it was at around 1.7GB, its currently sitting at 323mb.
  7. #7
    tvouge's Avatar
    Posts
    Global Posts
    248 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy S4: Where is my memory going?
    For the most part, the cache is a good thing--- for the apps you use all the time. It really speeds up transitions and reduces processor (and hence battery) use. But it's good to clear it once in awhile to get rid of garbage you're not using.
    UJ95x likes this.
  1. lock screen keeps showing that my music player is running
    By Hunter Barker in forum Samsung Galaxy S5
    Last Post: 05-15-2014, 02:35 PM
  2. Where's the Lifeproof case?
    By Ry in forum Moto X (2013)
    Last Post: 05-09-2014, 12:09 PM
  3. Replies: 1
    Last Post: 04-24-2014, 10:18 PM
  4. regret rooting my m8 (Barclays issue)
    By xploitUK in forum HTC One M8
    Last Post: 04-24-2014, 08:05 PM
  5. Replies: 3
    Last Post: 04-24-2014, 07:11 PM
