1. dickharper's Avatar
    I used to be able to connect my S4 to my PC with the charging USB cable and it would recognize the phone and I would go to My PC and get in my phone and transfer files in and out of my phone. I can't do that anymore. PC does recognize the phone, I can see the USB icon on the notification panel, but when I go to My PC there is nothing there.
    My current Android version is 4.4.2. I tried using the *#0808# code and tried several different options and none worked. I tried using Samsung Kies and nothing.
    05-01-2014 01:27 AM
  2. Kelly Burby's Avatar
    Well, while connecting your device to the PC a notification must be popping up on your device asking for the how to use the device i.e. either using the MTP (for using it with kies) or using it as camera (for using it like a USB device). I will say try changing it to use as the MTP device (for using it with Kies), if its still on the MTP try restarting your device !! if still that doesn't works try connecting your device using the different USB cable.
    05-01-2014 02:37 AM
  3. alexcolka's Avatar
    Sometimes restarting the phone connected to the pc may do the trick.
    Sent from my GT-I9500 using Tapatalk
    05-01-2014 09:09 PM
  4. dickharper's Avatar
    I said I already tried the different methods, I tried MTP, I tried using it as camera. I restarted my phone countless amount of times. Nothing has worked. Kies wont recognize the phone either.
    05-01-2014 10:20 PM
  5. Richard Pierce1's Avatar
    Finally solved the same problem after hours of work. A New cable did not work and then found that the phone pull down menu showed "charging" Touching on that icon brought up a menu and I selected "file transfer" and everything went back to normal. The computer now sees the files in the phone.
    07-24-2016 05:19 PM
  1. APN Settings for AT&T M8 used on T-Mobile??
    By Lilshaq65 in forum HTC One M8
    Last Post: 09-18-2014, 07:50 AM
  2. Chromecast with $80 Tmobile plan as sole Internet?
    By shinydiscopants in forum Google Chromecast
    Last Post: 06-02-2014, 10:49 AM
  3. Replies: 3
    Last Post: 05-09-2014, 11:56 AM
  4. Verizon galaxy s4 from 4.2.2 to kitkat
    By UNCMo96 in forum Verizon Samsung Galaxy S4
    Last Post: 05-01-2014, 03:14 AM
  5. 4G no longer dims when Wifi connects
    By bearcatflex in forum General Help and How To
    Last Post: 04-30-2014, 10:35 PM
