Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Like Tree4Likes
    Omer San Gabriel's Avatar
    Posts
    Global Posts
    379 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Does battery saving apps really work?
    As said in the title... Does it really work? Apps like DU Battery Saver, JuiceDefender and Battery Doctor. Or it just drains more battery?
    Thanks for the feedback.
    ttim60 likes this.
  2. #2
    mobilecrackers's Avatar
    Posts
    Global Posts
    538 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Does battery saving apps really work?
    large screen phones I don't think so.that application might work in low quality phones but not the large screen phones
    Sent from my GT-N7100 using AC Forums mobile app
  3. #3
    Tsepz_GP's Avatar
    Posts
    Global Posts
    1,099 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I once tried JuiceDefender in 2011 on my Galaxy S2 at the time, didn't see a difference TBH, never tried again.
    Some advice:
    Go to Power Save Mode, Enable it, and tick Screen Power Saving, that's what I've done.
    You can also turn on CPU Power Saving, all this put together with the app Greenify is an excellent power saving technique.
  4. #4
    alexcolka's Avatar
    Posts
    Global Posts
    192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't see any improvements with this kind of apps, by the contrary drained more battery in my case. Having a closer look to the apps that use the location settings improved a lot my battery life.
    Sent from my GT-I9500 using Tapatalk
  5. #5
    Tahoe916's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I recently switched from Juicedefender to Greenpower premium, its doing much better at reducing my battery usage.
    I'm at 83% right now with 7 hours on the battery. It may help though that I put in a new battery I bought.
    Sent from my SCH-I545 using AC Forums mobile app
  6. #6
    Almeuit's Avatar
    Posts
    Global Posts
    23,273 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    I don't like them. They didn't help me at all when I tried them a long time ago.
    Sent from my T-Mobile Note 3 using AC Forums.
  7. #7
    Sanjay Chandra's Avatar
    Posts
    Global Posts
    812 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Best power saving technique is to use the power saving mode given by Samsung/OEMs because it works both on hardware and software level rather than normal apps which just control brightness and stuff which doesn't help in better battery in any way.
    If you really want better battery life, don't constantly off and on location services. Keep it either on or off.
    If you travel, put off location services because it constantly tries to watch the wifi hotspots and networks and try to report location to google which might use up battery life a lot.
    Poor signal coupled with your phone trying to load stuff is the number one reason which causes battery drain most of the time.
    Don't clear RAM because resuming apps on RAM is much better battery saver than restarting the apps again and again.
    I never use any anti virus apps or battery savers or cache cleaners (which half of the time mess up things than fix them).
    Don't clear cache unless you are out of storage or didn't clear it for a month.
    Half the time, people make battery life worse by cleaning cache or clearing RAM which puts more pressure on the processor to reloading things.
    Let the system do its work. Android automatically does everything for you. OEMs provide power saving mode optimized for that hardware.
    P.S I once installed RAM usage meter on my iPad and I was shocked to see that system constantly takes up 80-90% of the RAM all the time.
    I didn't even notice it until I installed the app. Android and iOS automatically manage your RAM.
    Free RAM = waste RAM. No use of having 500MB free RAM because its useless without using it.
    Linux and mobile OS works different from Windows PC. So, free RAM in windows is different from free RAM in Linux. (google search it)
    Sent from my GT-I9500 using AC Forums mobile app
  8. #8
    alexcolka's Avatar
    Posts
    Global Posts
    192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Really nice explanation, I agree with this way of using the phone.
  9. #9
    Murph5150's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Euroskank CM10
    Battery Guru has seemed to slightly improve my battery life. But I can already tell that my battery is starting to lose its life from time and charging cycles.
    ttim60 likes this.
  10. #10
    Tahoe916's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The apps claiming to save battery are not all the same, I agree with Sanjay that clearing RAM isn't going to help much. Maybe if you have a poorly behaving app but those are best off being removed.
    The only battery saving app method I think helps is where the app keeps your wifi, mobile data (and bluetooth if you can) off when the phone is on standby, and turns it on only on a scheduled basis and when you turn the screen on. I set mine to every hour. You still get calls and SMS messages. It's just not good if you have a background app you need running all the time, like voice over IP, but you may be ok with setting a more frequent rate like every 5 minutes, but with less battery savings. Me and a friend had seen about 20% more battery life doing this. If your phone is not in standby much then I'd expect much less benefit. It also addressed periodic severe battery drain when I was inside buildings with a very weak signal and the phone actually got hot as it kept trying to connect.
    I haven't tried the built in power savings and have great battery life for now. I already have haptic off. I don't know about the screen power savings, my concern has been more about the excessive drain on standby. The CPU power savings would probably help but I don't like the idea of buying a high end phone and crippling the processor. Maybe if it only slows it down while in standby? I don't get that impression though.
  11. #11
    Posts
    Global Posts
    812 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How much phone usage are you getting ?
  12. #12
    Not Quite Right's Avatar
    Posts
    Global Posts
    1,411 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Short answer no. You know what does work? Plugging your phone in ...
  13. #13
    dm3ready's Avatar
    Posts
    Global Posts
    449 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Murph5150 View Post
    I agree. I use Battery Guru because it was designed by the same company that made my processor: Snapdragon. (I have the SGH-i337)
  14. #14
    Tahoe916's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yesterday I was at 42% after 15h 19m with the screen on for 1 hr 32min. Right now I'm at 49% after 11h 51m with 1h 49m on the screen. I use it very little as a phone, mostly SMS and apps. I've some real frustrating battery issues in the past so I've tried so many things. It would sometimes get really hot with a fast drain lasting barely 8 hours. Unfortunately I switched to a new battery at the same time I switched to the Greenpower app, so I don't know which of the two is more responsible for it being much better now.
    Quote Originally Posted by Sanjay Chandra View Post
  15. #15
    waynemxwell's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Battery saver apps cheating smartphone users which make brightness low as possible which may increase stand by time.the problem is these saver apps run in background consumes more battery.Im using core prime which has samsung's ultra power saving mode which last battery to days.....apps like clean master speed up charging time and clean junk
  16. #16
    iggy67's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I took my phone to the AT&T store where I got it and they said to restart it in recovery mode and scroll down in the menu to wipe cache partition, run it and than reboot back to normal mode. The said to do this if it starts being slow or you notice any battery drain. Also they said do not download any battery savers or task killers because they don't work. They said a app to for monitoring usage is Watchdog it watches for misbehaving apps
    and if it finds one it will alert you.
  17. #17
    CAB1024's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I wouldn't believe anything an AT&T rep told me. In fact I'd assume the opposite were true.
    I know that CM's Battery Saver both extended my battery time, but more importantly, reduced my charging time dramatically on my Galaxy Note 2.
    But I cam here to find a comparison of effectiveness of the better apps. I'm going to try Battery Guru now, since as a previous poster said, it's made by the same maker of the phone's chip.
  18. #18
    CAB1024's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I take that back -- it's not compatible with my phone...
  19. #19
    charitytowin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just because he works at an AT&T store doesn't mean he doesn't read tons about phones and such. don't be a hater
  20. #20
    CAB1024's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    YMMV...
    Just installed DU Battery Saver. Don't like it, and several feature are paid-only for the PRO version. Switching back to BatteryDoctor and going to try to recoup the last half-hour of my life.
  21. #21
    CAB1024's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm following some of Mr. AT&T's advice...(not gonna be a hater!) I wiped my cache partition, and for one thing the phone (which is on a custom ROM to get Lollipop on a Note 2) rebooted way quicker than it usually does. And I'm going to install Watchdog and see what that tells me.
  22. #22
    Crashdamage's Avatar
    Posts
    Global Posts
    1,992 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My Rant of the Day...
    Quote Originally Posted by waynemxwell View Post
    They do not, cannot, have any effect on charging time. Cleaning junk rarely, if ever, needs to be done and has no effect on performance. And you should never, ever install anything by Cheetah Mobile!
    Quote Originally Posted by CAB1024 View Post
    Impossible for it to cut charging time. Simply. Impossible. See the links below about Cheetah Mobile products and why they should be considered malware!
    DU Battery Saver is one of the worst apps ever available for Android. Ineffective - yes it is, like all such so-called battery savers. Worse, it throws up nag ads, false scary-sounding warnings, etc. And maybe even worse than that, like Cheetah Mobile apps, DU data-mines your info and sends it back to DU and to who knows who else. All apps by DU and Baidu (DU's parent company) should be considered malware and avoided at all costs! Battery Doctor is another Cheetah Mobile app. Enough said.
    See these links and the links in them for more information:
    The 1st link inside this link is a long thread about DU Battery, Battery Doctor and much, much more. A veritable treasure trove of good information and knowledge by some very smart people. The other links are good too.
    http://forums.androidcentral.com/sho....php?p=4435166
    This list of apps and companies to be avoided barely scratches the surface of what's out there, but it should help a little:
    Antivirus on Android or not?
    Some other info that might be helpful:
    http://forums.androidcentral.com/sho....php?p=4655557
    EDIT: I goofed and put some wrong links in this. Changed the links. Sorry for any inconvenience.
  23. #23
    extraclass's Avatar
    Posts
    Global Posts
    628 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Before installing any App look at the permissions it ask for. A battery saving App does not need to look at your contacts and photos or music! I started to install an App and it wanted access to everything on my phone. Just say NO to any App like this!
    Crashdamage likes this.
  24. #24
    Abraham Murciano Benzadon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I did a small test to see if battery doctor worked;
    I installed it, opened it and it said my battery was in terrible condition and gave the impression that it was the end of the world...
    I then cleaned the battery and then I was told that the battery was in good condition.
    I then cleared the data of the app and opened it again, and once again it told me that the battery was in terrible condition
    Basically it doesn't work...
  25. #25
    Jenneikaz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My lg k7 would be 100% when I wake up. But then dead by noon. it's a brand new phone. Just got it in January! And I. Not using any of those apps. I leave battery saver on all the time and keep he screen dim nothing does any good.
  1. cool new app
    By monesinter in forum Accessories
    Last Post: 10-24-2015, 07:25 PM
  2. [APP][FREE] Android Network Info Release
    By abc1411 in forum Android App Inventor
    Last Post: 10-10-2014, 05:35 PM
  3. ZTE Unico LTE SD card apps shortcuts
    By psdnakita in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-08-2014, 12:47 PM
  4. lg Tone+ hbs730 not working on s5
    By Jessica Erickson in forum Samsung Galaxy S5
    Last Post: 07-02-2014, 11:46 AM
  5. Replies: 0
    Last Post: 05-03-2014, 01:33 AM
