Results 1 to 4 of 4
    Jai_mk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Angry Samsung S4 4.4.4 GT-I9500 memorry issue when connected as USB storage to PC
    I got a Samsung S4 GT-I9500. When I tried connecting it to Windows 8 pc, the drive shows storge of 12.1 MB onl.
    While phone settings show 8.6 GB of available storage.
    I am newbie in this field. So can anyone help??
  2. #2
    Corey King's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Samsung S4 4.4.4 GT-I9500 memorry issue when connected as USB storage to PC
    do you have a removable sd card inside the phone? also what is the name of the drive on the computer?
    Jai_mk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I removed the sd card. The drive shows as I: drive with 12.1 MB total space.
  4. #4
    BadgerVadge907's Avatar
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try it with the sd connected. ALSO you need to download the samsung USB drivers, or use Samsung KIES for it to work properly.
    You can unlock the Developer's options in the settings menu by pressing the build number several times, and then toggle the USB debugging ON, see if that does anything.
  1. Replies: 4
    Last Post: 06-27-2014, 02:26 AM
  2. How does the Droid Maxx compare to the older Razr Maxx
    By bluwtr49 in forum Motorola Droid MAXX
    Last Post: 05-19-2014, 12:08 AM
  3. S3 to S4 - Titanium Backup restore
    By zetodavido in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 05-14-2014, 01:28 AM
  4. Replies: 31
    Last Post: 05-08-2014, 09:20 PM
  5. GPS signal sucks after USB replacement
    By testmonket in forum Sprint Galaxy Note 2
    Last Post: 05-05-2014, 07:58 PM
