Results 1 to 4 of 4
    jedidev's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy hot screen sudden battery drain
    As the title suggests, my s4 has started getting very hot at the top of the screen and back of the handset. Its an intermittent thing. More frequent since last week when my network released the Kit Kat 4.4 update. I've tried a factory reset which worked for about 3 days. The most curious thing is the battery life, earlier on it got hot and I restarted the phone to see if it was software related and the battery was on around 30-40% after the reboot it was 19%. I've included a Screenshot of the Vertical battery drain at that point.
    long story short is this a hardware fault or the updates fault? I'm lost...
Name:	S4 Battery drain.jpg
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,075 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: hot screen sudden battery drain
    Quote Originally Posted by jedidev View Post
    Welcome to the forums.
    Your mobile signal went red about the same time as the battery drain. It might have been pulling every power resource it could to maintain the signal. Who is your carrier?
    jedidev's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi, thanks for the welcome
    My Carrier/network is 3 (Three UK).
  4. #4
    Posts
    Global Posts
    33,075 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I would try a cache clear in recovery to see if that helps.
    Try this: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    Follow steps for the S3.
    Sent from my HTC One_M8 using AC Forums mobile app
  1. App shortcut size and screen brightness
    By grabaka in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 06-11-2014, 05:11 PM
  2. "Screen" Protector For Back Of Phone
    By NickA in forum HTC One M8
    Last Post: 05-11-2014, 03:54 PM
  3. Screen Brightness Question Since KK Update
    By alcor34 in forum Verizon LG G2
    Last Post: 05-10-2014, 12:04 PM
  4. Steaming music via BT sucked battery dry.
    By 1812dave in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-07-2014, 11:09 PM
  5. Replaced digitizer on ZTE Majesty, now have horizontal lines on screen
    By Kayla Terry in forum General Help and How To
    Last Post: 05-06-2014, 02:24 PM
