1. Omer San Gabriel's Avatar
    Hi guys, i'm not that much of a heavy user in terms of using the phone but the real thing that is HUGELY draining my battery is the Mobile Data + Hotspot. Not all of my friends has Hotspot capable device/has data plan so when we hangout they always request me to turn on my mobile data and hotspot on so they can also check their social accounts etc.
    So i just want to ask, for my usage as said above. What is more ideal to buy? A bigger battery which has that lumpy back or a power bank which is like another phone that you are carrying.
    05-07-2014 10:54 AM
  2. mhinc's Avatar
    Personally I have the PowerBank. Not a fan of the larger battery, as I am very specific about the case I used and it won't fit. Also you can leave your powerbank in your car, glove box, whatever. And pull it when you need it. The bulky battery is ALWAYS just that, bulky!
    Just my 2 cents!
    Omer San Gabriel likes this.
    05-07-2014 03:22 PM
  3. clickerman's Avatar
    I recommend you just carry an extra battery or two with you.
    Sent from my SGH-M919 using Tapatalk
    05-07-2014 04:21 PM
  4. mhinc's Avatar
    That's a pain in the *** if you have a case, especailly if you have something like an otterbox where you have to take off 2 layers to get to it each time
    05-07-2014 06:33 PM
  5. mykl376's Avatar
    I used an extended battery in my previous phone, a Droid Bionic, and it was nice to have the extra juice, but after I got my S4, I just didn't want to have that extra thickness and weight anymore. I would go with a powerbank and/or just a spare battery. If you get a spare battery, be sure to get a charger for it, that way you can charge it without having to use your phone as the charger.
    05-08-2014 06:44 AM
  1. New OEM batteries on ebay, real or not?
    By 3rdpig in forum Samsung Galaxy S5 Accessories
    Last Post: 07-08-2014, 12:39 AM
  2. Loose battery cover
    By Eclipse2K in forum Samsung Galaxy S5
    Last Post: 05-07-2014, 11:33 PM
  3. Battery Question??
    By ep70 in forum Samsung Galaxy S5
    Last Post: 05-07-2014, 01:05 PM
  4. Snapdragon Battery Guru ??
    By Jalopiejoe in forum Samsung Galaxy Note 3
    Last Post: 05-06-2014, 10:00 PM
  5. Galaxy S3: Isn't Getting Power It Seems
    By rasmusuperfan in forum Samsung Galaxy S3
    Last Post: 05-06-2014, 05:25 PM
