1. SherbetDibDab's Avatar
    Basically had my S4 for 9 months and ive been happy with it until about a week ago it started playing up random freezes and apps that wont start and then the phone might just randomly restart change my wallpaper and home screen around like its reset itself to a previous date?? Its a bit worrying because nothing new has changed ;( can anyone shed some light on this? Any fixes or know problems
    P.S the phone gets really hot now
    Thanks folks
    05-09-2014 03:31 PM
  2. B. Diddy's Avatar
    Things to try first include:
    1. Check the battery to see if it's going bad. Remove it, lay it flat on a table, and try to spin it. If it spins freely, that means it's bulging in the middle, which is a bad sign. Get a new battery.
    2. Unmount and remove the SD card, and reboot. Try a different SD card if you'd like. If the SD is corrupt, it can lead to various glitches.
    3. Try wiping the system cache partition, which won't erase any personal data: Reset: Samsung Galaxy S 4 | T-Mobile Support
    05-09-2014 06:34 PM
  3. firemanb72's Avatar
    Do you have Flash Player 11 installed from Adobe? I removed my add on Flash Player and most of my freezing stopped.
    05-11-2014 08:14 AM
  1. Qi Wireless Receiver and Otterbox
    By JimA in forum Samsung Galaxy S5 Accessories
    Last Post: 03-02-2015, 08:47 AM
  2. [FREE][GAME] Snake and Fruits
    By sskumar21 in forum Android Games
    Last Post: 02-22-2015, 06:28 AM
  3. Help with process android.process.acore Samsung SG2
    By Crunchwantsfood in forum Android 2.3 Gingerbread
    Last Post: 06-11-2014, 01:20 PM
  4. Help for noobie
    By jacobjanzen in forum Sprint HTC One
    Last Post: 05-13-2014, 11:16 PM
