1. carguy37757's Avatar
    Sorry if this has been discussed, but I couldn't find anything in search.
    My wife and I have bone stock, non-rooted S4'son Verizon. Since the update all has been well except for SMS messaging randomly not working. I performed a factory reset with no help, tried installing another messaging client with no help, and using hangouts which I thought helped but must have been a fluke because it no longer works regularly either.
    Anyone else having this issue or a solution?
    Sent from my SCH-I545 using Tapatalk
    05-11-2014 09:35 AM
  2. mhinc's Avatar
    Can you be more specific as to what exactly is happening? "SMS messaging randomly not working" is very vague.
    Are you not receving? Sending? Are you getting any errors? Do you have full bars? Are phone calls normal?
    Please give a detailed run down of the issue.
    Also, since your texts are part of the network just like phone calls, have you called Verizon, so far, unless you provide more info, it sounds like a
    network issue with Verizon and you should call their tech
    05-11-2014 01:23 PM
  3. carguy37757's Avatar
    Calls work fine. Messaging just doesn't seem to work at all, sending or receiving. Happens at various signal states. Affects texts and MMS messages alike.
    I've not called Verizon yet as they rarely help as much as the knowledge base here and on other sites.
    05-11-2014 05:42 PM
  4. mhinc's Avatar
    As helpful as this site may be...Unfortunately it's sounding like it is a Verizon side issue. If the phone was unlocked then I would suggest checking your APN settings for Texts and MMS. But since it's non rooted, from Verizon I can't see that being the case. I hate to say it but I think you need to call the, as it's sounds like their problem.
    Please let us know what the outcome is
    05-12-2014 11:58 AM
  1. Replies: 2
    Last Post: 04-25-2015, 01:42 AM
  2. Really weird S Health issue
    By bigmouthmedia in forum Samsung Galaxy S5
    Last Post: 01-08-2015, 03:51 PM
  3. Do you think there's any security issue with sms in Hangout?
    By jokerdud in forum Android Security Apps, Tips & Strategies
    Last Post: 08-03-2014, 12:17 AM
  4. S4 4.4.2 Items missing
    By firemanb72 in forum Samsung Galaxy S4
    Last Post: 05-11-2014, 09:45 AM
  5. Charging issue
    By firsttimer44 in forum HTC One M8
    Last Post: 05-11-2014, 07:40 AM
