Results 1 to 7 of 7
    lesrourou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default verizon cdma to gsm
    im going to buy a galaxy s4 (4g lte) verizon . the only problem is that im in tunisia so theres no cdma networks (gsm only )
    my country networks are tunisiana (changed its name 2 weeks ago into ooredoo) tunisie telecom and orange
    should i buy the phone and how to turn it into a gsm phone with 3g access so taht i can use one of those networks
    and thanks
  2. #2
    palandri's Avatar
    Posts
    Global Posts
    9,915 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: verizon cdma to gsm
    here are the 3G frequencies:
    850 Cellular / band 5 (V) Americas, Oceania, Brazil, Israel
    1900 PCS / band 2 (II) Americas
    2100 IMT / band 1 (I) Europe, Asia, Africa, Oceania, Brazil, India, Israel
    If that's what ooredoo uses, you should be fine. Just stick in the SIM card and see what happens. You may have to manually set up data/SMS/MMS
    lesrourou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    http://soutien.bell.ca/_web/guides/U..._Hint_Tips.pdf check tunisie in 5th page (tuntel is tunisie telecom)
    ooredoo (or tunisiana) uses 2 bands for 3g 900 and 2100 (2G Network GSM 850 / 900 / 1800 / 1900
    3G Network HSDPA 900 / 2100
    HSDPA 850 / 1900 or HSDPA 850 / 2100 source : THD - THD its in fench)
    and orange uses i guess something between 1900 and 2200 for 3g
    tunise telecom 900-800-2100 i guess (or 900-2100)
    so i dont know .what do you think ?will gsm work ?and 3g too? and how to manually set data-sms-mms
    lesrourou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i might not be on for the next couple of days so i wont be responding to questions (i will when i log on on weekends )
    and please dont use any difficult words cause english isnt my primary language
    lesrourou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    so if i just stick a gsm in there it will work? even 4g lte when its released?
  6. #6
    patrixl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I wouldn't chance it. Verizon locks down their phones a lot, plus it's primarily a cdma phone, with gsm included for roaming more than for sticking foreign sim cards.
    Sent from my HTL22 using Tapatalk
    lesrourou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    so i dont buy it?
  1. Replies: 2
    Last Post: 04-25-2015, 02:42 AM
  2. Verizon S4 SMS issue
    By carguy37757 in forum Samsung Galaxy S4
    Last Post: 05-12-2014, 12:58 PM
  3. Unable to connect to other devices via USB???
    By MARKYSTEW in forum Samsung Galaxy S4
    Last Post: 05-11-2014, 04:02 PM
  4. Forcing Google Camera to store pics/videos to SD
    By InGrazAT in forum Samsung Galaxy S4
    Last Post: 05-11-2014, 11:37 AM
  5. I gotta stay still to take good quality pics?
    By Bayarea13 in forum Samsung Galaxy S5
    Last Post: 05-11-2014, 08:09 AM
