1. tmozer's Avatar
    I have three WiFi routers I need to connect my AT&T S4 to. I have no problem connecting to my Comcast router. I have hit or miss connection issues with my TWC router. Here is NJ I cannot get the S4 to connect to my Optimum router. It will connect to a weak hotspot that apparently is close enough (with a low signal level), but will not connect to the router sitting here in the bedroom.
    What should I try to trouble shoot these issues??
    05-11-2014 02:52 PM
  2. mhinc's Avatar
    If these routers are provided by your ISP ie. Time Warner or Comcast. They may not have the typical default settings. It's normally very simple. Set up your SSID ie Connetion Name. on a WPA2 secure connection and set a pass phrase, and it's there and able to be connected to. To have 3 routers that are all not working correctly either means you are doing something wrong, or their config is not allowing your phone to connect. So contact the ISP's they are owned and provided by and see what they say.
    05-11-2014 03:00 PM
  1. Do you think there's any security issue with sms in Hangout?
    By jokerdud in forum Android Security Apps, Tips & Strategies
    Last Post: 08-03-2014, 12:17 AM
  2. Verizon S4 SMS issue
    By carguy37757 in forum Samsung Galaxy S4
    Last Post: 05-12-2014, 11:58 AM
  3. Unable to connect to other devices via USB???
    By MARKYSTEW in forum Samsung Galaxy S4
    Last Post: 05-11-2014, 03:02 PM
  4. MapMyRun sometimes loses BT connection to watch (2 watches; 2 Note2's)
    By 1812dave in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-11-2014, 02:31 PM
  5. Charging issue
    By firsttimer44 in forum HTC One M8
    Last Post: 05-11-2014, 07:40 AM
