1. droidntn's Avatar
    I've SOLVED the Galaxy S4 battery problem! I can go alllllll day now without hunting down a charger!-41gwptaorcl.jpg
    I gave up on tweak this, try that, turn the screen down. bla bla bla.
    Just be done with it and get a Mophie case. lol.
    I did, it's 80 bucks but it's well worth having a 'cordless day' and not having to mess with it anymore.
    Just plug in at night like normal, when it gets low..Just flip a switch on the back of the case. and I'm good to go until bedtime.
    Oh and the built in speakers on the front of the case rock.
    You're welcome.
    05-15-2014 12:24 PM
  2. dpham00's Avatar
    Fyi, you can also use an extended battery.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    UJ95x likes this.
    05-15-2014 12:29 PM
  3. droidntn's Avatar
    Sure but then you'll need a bigger case too. This charging case fits the bill.
    Sent from my SCH-I545 using AC Forums mobile app
    05-15-2014 03:24 PM
  4. THEPRFCT10's Avatar
    You're welcome.
    Built in speakers? Is there a connection or something? The S4 just has the single speaker on the back and I thought the Mophie completely covers the rear speaker. Please help me understand, thank you.
    05-15-2014 04:43 PM
  5. droidntn's Avatar
    On that pic.. These two little things to the right and left of the Mophie logo... Those are speakers my friend.
    05-15-2014 05:23 PM
  6. THEPRFCT10's Avatar
    Ok very cool. Forgive my ignorance, but how are they connected? Bluetooth? Wired somehow?
    05-15-2014 05:47 PM
  7. Murph5150's Avatar
    I have a Mophie Juice Pack too. I was unaware the S4 had an available extended battery.
    05-15-2014 06:40 PM
  8. droidntn's Avatar
    Honestly I'm not sure lol.
    All I know is I put the case on and it plays.
    05-15-2014 09:34 PM
  9. THEPRFCT10's Avatar
    Lol, well cool if they work! Honestly that was the only reason I didn't get one was because I thought that the sound would be blocked or muffled at best since the speaker is in the back covered by the Mophie case. Volume good too?
    05-15-2014 09:39 PM
  10. droidntn's Avatar
    Yes it's fine.. Not really loud but much improved over the S4 speaker
    05-15-2014 09:49 PM
  11. Sanjay Chandra's Avatar
    Guys, I am curious what takes up so much of your battery life ?
    Sent from my GT-I9500 using AC Forums mobile app
    05-15-2014 09:59 PM
  12. droidntn's Avatar
    Well there's mine. And that's with the Mophie case adding a little Juice earlier today bumping it from 50 back up to around 75 about 3 hours ago.
    Crazy battery life. It's so dependent on YOU to keep the settings and B things right so that it doesn't chew up your battery.
    Attached Thumbnails I've SOLVED the Galaxy S4 battery problem! I can go alllllll day now without hunting down a charger!-1400270613775.jpg
    05-16-2014 03:06 PM
  13. VidJunky's Avatar
    From what I've seen they are not speakers they redirect the sound thru channels to bring the sound to the front of the phone, because the case covers the speaker.
    If you’ve used a Mophie battery case before, you’ll know that it adds a considerable amount of bulk to your phone. But if you’re spending all day at a conference with questionable access to power, you’ll know that it can be well worth the added pocket real estate. Mophie has also done a good job at refining their passthrough buttons and switches to the point where they’re almost as easy to use as the originals on the phone itself. The metal plate surrounding the micro USB connector at the bottom of the case adds durability, and the speaker redirect channels make it easier to listen to content through your iPhone’s own audio drivers.
    Granted this ad is for the iPhone.
    05-17-2014 09:04 AM
  14. mhinc's Avatar
    You're welcome.
    There are NO SPEAKERS on this case. It's simply holes, and they have routed the sound from your current S4 speakers from the back to the front.
    That's it, that's all! No wizardry or magic. So those "Rockin' Speakers" are the same ones you rocked out to before...
    Deanig_12 and droidntn like this.
    05-17-2014 11:24 AM
  15. droidntn's Avatar
    Ok, I don't care if it's a set of waffle irons..DOOD...I can hear my Aerosmith on my phone now.
    05-17-2014 12:50 PM
  16. mhinc's Avatar
    Point being, you obviously don't research the products you buy, as you had no idea that you actually didn't get new speakers.
    And others DO CARE hence why I made a point to let them know before they run out and get this case you are going on about
    thinking they are going to get better speakers included when it's just 2 holes to reroute sound.
    05-17-2014 01:33 PM
  17. droidntn's Avatar
    True. I just bought it. And enjoy it. Sorry if I gave someone the impression that it's a Bose. I was so embarrassed when I called all my friends over for a house party and pulled out my phone and I was like check out these speakers! And then one of my buds brought it all down and said hey let's split.... These aren't SPEAKERS? Wth? These are just two holes!
    Man, I hate that when my lack of cell phone research let's people down.
    05-17-2014 02:50 PM
  18. mhinc's Avatar
    Ya, it's pretty obvious from your reply what age group you fall into. The generation of entitlement. Punk teen, and if you aren't a teen then you need to grow up bud.
    I am done arguing with stupidity
    droidntn likes this.
    05-17-2014 06:56 PM
  19. droidntn's Avatar
    Indeed.
    Never argue with a fool; onlookers may not be able to tell the difference. Mark Twain
    05-17-2014 07:06 PM
  1. Something is eating my battery!!
    By kami8586 in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-22-2014, 11:44 AM
  2. Crazy battery life on Galaxy S4
    By Yousef Amarneh in forum Samsung Galaxy S4
    Last Post: 05-19-2014, 05:07 PM
  3. Newbie here :) Just got my S4!
    By Red_Berry_21 in forum Samsung Galaxy S4
    Last Post: 05-18-2014, 03:34 PM
  4. Replies: 3
    Last Post: 05-18-2014, 12:10 AM
  5. Can you select location access by app?
    By Davemcc in forum HTC One M8
    Last Post: 05-16-2014, 06:14 PM
