Results 1 to 5 of 5
    Default Need an app that will auto connect the S4 Bluetooth to the car
    Currently I am using the app Bluetooth Auto Connect but it should be more apply named Bluetooth Auto Disconnect. I have tried a lot of apps but none have auto connected me to the car. The car's bluetooth does recognize the S4 but each time the S4 needs to be manually paired for the system to talk with each other. Can anyone suggest an app that they had better success with that will auto connect? Thanks.
  2. #2
    Default Re: Need an app that will auto connect the S4 Bluetooth to the car
    Quote Originally Posted by sad cricket View Post
    This is an issue with the CAR not the phone needing an APP. The vehicle should be automatically grabbing your phone when you have bluetooth on, have you gone through the menus on the car setup?
    Yes, the setup is correct. The car would be searching for a Bluetooth connection however the phone for some unknown reason does not automatically trigger BT. I have to manually turn on BT on the phone each time.
  4. #4
    Murph5150's Avatar
    Posts
    Carrier
    Euroskank CM10
    Do you manually disengage Bluetooth when you're done driving, or does the phone disengage itself?
  5. #5
    Try using Tasker. The best automator functions. Connect and disconnect the Wi-Fi networks automatically via phone tracking antennas. You just can automate everything including the bluetooth. You just need to figure out the commands. Use it greatly. Follow the link:
    https://play.google.com/store/apps/d...ndroid.taskerm
    Enviado de meu XT1058 usando Tapatalk
  1. Samsung messaging app
    By davaus10 in forum Samsung Galaxy S5
    Last Post: 12-11-2015, 02:42 PM
  2. Replies: 3
    Last Post: 05-19-2014, 02:08 PM
  3. is Samsung's tablets going to have tizen on them?
    By ahawkua in forum General News & Discussion
    Last Post: 05-18-2014, 03:44 PM
  4. Totaly wiped the OS on my 925 and teh ex mem card. Need help.
    By septaric in forum RAZR Rooting, ROMs, and Hacks
    Last Post: 05-18-2014, 12:38 PM
  5. Replies: 0
    Last Post: 05-17-2014, 04:48 PM
