1. lakcore's Avatar
    My galaxy S4 battery drains extremely fast. I'm pretty certain it's from the phone constantly looking for service when there is none. I can literally watch my battery drain and the percentage go down well using it. Here are some screen shots of my battery usage. Any help is appreciated.
    Attached Thumbnails S4 Battery Drain Help. I'm a newbie.-screenshot_2014-05-18-13-28-39.jpg   S4 Battery Drain Help. I'm a newbie.-screenshot_2014-05-18-13-28-46.jpg
    05-18-2014 01:29 PM
  2. B. Diddy's Avatar
    Welcome to Android Central, and holy cow, that is horrible reception. You're right, that's a big part of the battery drain. What wireless provider do you have? Is the reception poor at home, at work, or everywhere? I would suggest switching to another provider that has a better signal.
    In the meantime, you could always switch to Airplane Mode when you're not using your phone and aren't expecting calls. That turns off your cell radio. You can always turn wifi on.
    05-18-2014 01:34 PM
  3. lakcore's Avatar
    I have Verizon. And it seems that it drains everywhere. I usually turn it off for two hours well I'm in class so I can make it through the day.
    05-18-2014 01:40 PM
  4. B. Diddy's Avatar
    Wow, surprising that Verizon has such poor signal, since their reputation is for the widest coverage. Do other people with Verizon have the same poor signal in your area? If not, then maybe there's a problem with your phone.
    05-18-2014 01:44 PM
  5. lakcore's Avatar
    I'm the only Verizon in my house. I called Verizon too and they said I'm in a dead zone with zero coverage. Still not sure why it drains so fast while I'm in town with full bars.
    05-18-2014 01:46 PM
  6. B. Diddy's Avatar
    Review this guide and see if any of the tips help: [Guide] Battery Saving Tips
    05-18-2014 01:48 PM
  7. hwert's Avatar
    i had the similiar problem before and i think the best way is to get a replacement. I bought one from RAVPower and it works well with my S4.
    05-19-2014 09:11 PM
  8. prithvitheprime's Avatar
    Use power saving mode and make your screen brightness lighter.
    05-20-2014 01:20 AM
  1. ***Phone is dead, need help please***
    By septaric in forum RAZR Rooting, ROM's, and Hacks
    Last Post: 05-25-2014, 12:33 AM
  2. Sprint Galaxy S4 won't connect to Sprint
    By dougltc in forum Samsung Galaxy S4
    Last Post: 05-21-2014, 11:46 PM
  3. Discharging While Plugged In/Constant Battery Loss
    By romanguy13 in forum T-Mobile Galaxy S III
    Last Post: 05-19-2014, 02:50 PM
  4. question about nova launcher, can someone help please
    By all4dom in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-18-2014, 08:43 PM
