Results 1 to 6 of 6
Like Tree1Likes
  • 2 Post By JudH
    Default Turn of GSM setting
    Is this possible? Other than turning airplane mode ON and removing the sim card. Thanks
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Default Re: Turn of GSM setting
    Quote Originally Posted by Omer San Gabriel View Post
    Not getting what you are trying to say here ??? Can you please be more clear about it ?
    Quote Originally Posted by Kelly Burby View Post
    I mean like airplane mode but i can still use wifi but not the GSM.
  4. #4
    You can turn WiFi back on after entering airplane mode and the phone will stay off. There are some apps on play store that can break the link permanently, I.e. so that WiFi will not be turned off at all when you turn airplane mode on. Here's one:
    https://play.google.com/store/apps/d...planemodetweak
    UJ95x and Omer San Gabriel like this.
  5. #5
    Turn off Mobile data in the quick settings menu. Just remember to turn it on when you leave the WiFi hotspot
    Quote Originally Posted by JudH View Post
    Thanks a bunch!!! Problem solved!
  1. Calendar Events - Set Default Reminder Time?
    By JakePleasants in forum Samsung Galaxy S5
    Last Post: 01-18-2016, 01:23 AM
  2. S5 screen always auto turn on after lock
    By crunchor in forum Samsung Galaxy S5
    Last Post: 10-07-2015, 06:27 PM
  3. Replies: 1
    Last Post: 02-21-2015, 10:21 PM
  4. s3 mini - how to set default storage to sd card?
    By jrmama42 in forum Samsung Galaxy S3 Mini
    Last Post: 07-23-2014, 01:58 PM
  5. PC Game Streaming to Android Set-Top Box?
    By ridie1389 in forum General Help and How To
    Last Post: 05-18-2014, 08:44 PM
