1. spongy999's Avatar
    Hi, i'm hoping someone can help,
    while trying to sync using the 'easy phone sync' app for the samsung it asks 'do you want to remove these tracks' and shows a list of tracks,
    it then asks to choose yes or no by ticking a box and then asks to press continue, i always choose no, as i do not want these tracks which are mainly podcast tracks. i then press continue and it ENDS the sync without adding the album of which i have just downloaded to itunes.
    could someone help please but explain it in a very easy and simple way, as i'm not tech minded.
    much appreciated it you read this.
    regards
    spongy
    05-25-2014 05:41 AM
  2. mhinc's Avatar
    regards
    spongy
    Contact the developer
    05-25-2014 07:24 AM
