1. Tim Jones3's Avatar
    I have my phone charging while using it for gps and such. Im using more power then the charger is producing. Is there anything i can do about this?
    05-25-2014 04:36 PM
  2. jpr's Avatar
    Get a higher amperage car charger. Also turn of any features you are not using.
    05-25-2014 04:40 PM
  3. Tim Jones3's Avatar
    im using GPS with nothing else open...how much amperage will i need, or how would i find out how much amps i would need?
    05-25-2014 07:43 PM
  4. jpr's Avatar
    A 2.1 Amp charger. If you get the kind that you use your own USB cable instead of it being built in then get a charge only cable, not one for data transfer. Keep your screen brightness low as possible if you are leaving it on to view the navigation route (keep it light enough to view of course).
    05-25-2014 08:07 PM
  1. Samsung S5 MMS not sending?
    By baileysqueen in forum Samsung Galaxy S5
    Last Post: 03-24-2015, 09:15 AM
  2. Can not access my S5 through my iMac
    By grenfrog00 in forum Samsung Galaxy S5
    Last Post: 08-18-2014, 02:30 AM
  3. Cerberus not working after Kitkat update
    By jim2112 in forum Verizon Samsung Galaxy Note 3
    Last Post: 07-24-2014, 04:47 AM
  4. LG G2 Car Charger - What Can I Count On?
    By Phil3 in forum Verizon LG G2
    Last Post: 05-26-2014, 09:15 PM
  5. How to root Droid Razr HD with kitkat
    By FuttBucker in forum RAZR Rooting, ROM's, and Hacks
    Last Post: 05-25-2014, 10:30 PM
