1. aly5321's Avatar
    My laptop and computer's internet are working completely fine, and my phone even connected to my school wifi this morning. My home wifi was working last night (until midnight even), but stopped this morning. I have had the phone since September and the only problem I've had similar to this was once when I had no signal- but that was easily fixed with restarting the phone.
    When I restarted my phone this morning, it connected to the wifi after maybe 10 minutes. But now it won't connect even if I restart my phone.
    Can anyone help?
    (My phone is version 4.4.2 and I've got 3 gb of device storage left- not counting the SD card that I recently got)
    05-27-2014 03:21 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Review this guide and see if any of the tips help: http://forums.androidcentral.com/amb...-problems.html
    05-27-2014 03:27 PM
  3. mhinc's Avatar
    Can anyone help?
    Have you simply power cycled your modem/router? 9 times out of 10 this will correct an issue like you are having.
    In other words. If you have a seperate modem and router. Shut down all your PCs and devices. Unplug the modem and router from the power. If it's a phone modem it may have a battery backup. So you will have to remove the battery to kill power. If it's an all in one, same thing as above just one plug, and possibly battery.
    Once eveyrthing is shut down and your modem/router have no power. Plug just the modem back in first, if it's a combo unit plug it in. Wait for the ONLINE or CABLE light to go solid sometimes it will say INTERNET as well. Once that is solid, plug in the router. Then turn on all your devices. and reconnect to your WIFI as normal. Hope that helps.
    If that doesn't help you could always goto your router manufactures website and check for a firmware update for the router, this will reflash the router with the most recent updates ie. Problem Fixes.
    Let us know
    05-27-2014 05:36 PM
  4. IMFRSTR8D's Avatar
    I'm having an issue with connecting my Galaxy S4 to my home wifi. I powered my modem and other devices down, but I am still having connectivity issues on one phone. Are there any other steps I can take to resolve this issue?
    12-29-2014 06:38 PM
  1. Trick to opening charging flap
    By eyecon82 in forum Samsung Galaxy S5
    Last Post: 07-03-2014, 02:06 AM
  2. Replies: 83
    Last Post: 06-05-2014, 03:30 AM
  3. Gmail only updates when wifi is on
    By Webbie65 in forum Verizon Galaxy S III
    Last Post: 05-28-2014, 01:31 PM
  4. Battery problems causing Wifi settings to disappear!?
    By Scarymole in forum Samsung Galaxy S3 Mini
    Last Post: 05-27-2014, 11:35 PM
  5. My Ideal Phone
    By mistic99 in forum General News & Discussion
    Last Post: 05-27-2014, 02:56 PM
