Results 1 to 6 of 6
    Default Charging Problems on my S4
    For some reason, my phone does not charge when the screen is off. When I have a charger plugged in, I'll turn off the screen and all of a sudden my screen will turn back on and say that a charger is connected, just as if I connected a charger again. How do I fix this?
  2. #2
    Default Re: Charging Problems on my S4
    Quote Originally Posted by Defining View Post
    try different charge
    take out the battery and rotate it on a flat surface , if it rotates then the battery is damaged
    go to recovery and clear cache.
    If it rotates? Don't get what you're saying.
  4. #4
    Sometimes, when a battery goes bad, the internal cells rupture, and cause a bulge to appear in the battery. You see this when you hold the battery is up. Additionally, a bulge makes it able to spin like a top when placing the battery on a flat surface.
    I'm not sure, cause I'm using a ZeroLemon Extended Battery.
  6. #6
    the problem is the battery . you need to use original Samsung battery.
  1. broken charging port
    By LudaChris Fn Mac in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 12-15-2016, 12:34 AM
  2. My Note 3 displays 4k gb
    By dpham00 in forum Samsung Galaxy Note 3
    Last Post: 06-05-2014, 01:08 AM
  3. 2 phones on AT&T same line?
    By rob damiani in forum AT&T
    Last Post: 06-01-2014, 06:23 AM
  4. photo downloads show in drop down status bar on startup
    By creek4353 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-31-2014, 04:45 AM
  5. Verizon Samsung Galaxy S4 update 4.4.2 Kitkat NO MORE EMAIL
    By DroidReallySucks in forum General Help and How To
    Last Post: 05-30-2014, 10:56 PM
