Results 1 to 6 of 6
    Default choose input method notification
    Okay so whenever I open up meseges the choose input method keeps appearing in my status bar. I am using the google keyboard but it wont go away any ideas?
  2. #2
    Default Re: choose input method notification
    I use SwiftKey 5.0.1.77 on my Galaxy S4 and am asked to Choose Input Method every day, sometimes multiple times a day. I, too, want this to go away or at least decline in frequency a great deal.
  3. #3
    Is this what you're talking about?
    Attached Thumbnails Attached Thumbnails choose input method notification-screenshot_2014-06-18-08-22-05.jpg
  4. #4
    Yes..looking for help on this too, I keep getting the same notification.
  5. #5
    Goto Settings...
    Language and Input...
    Make SURE that only the Keyboard you want to use is checkboxed.
    Also leave a voice input checked.
    Backout to Settings...
    Apps...
    Find the Keyboards you don't use and either:
    'Uninstall' them...
    =OR= if they are part of the System ROM,
    'Disable' them...
    In some System ROMs, you can disable the apps ability to generate notifications via:
    a (an already checked ) Checkbox, uncheck it.
    You will not need root to use the above method(s)...
    Hope this helps...
    -Dejunai
  6. #6
    Made an account to post a link to a better answer than any on this page. Can't post links unless I have ten posts. So sorry this is in inconvenient format, but go to:
    gs4. wonderhowto. com/how-to/get-rid-annoying-input-notification-keyboard-icon-your-samsung-galaxy-s4-0147036/
    Make sure you delete the spaces after the periods in the above link ^^
  1. New Notification Icon on HTC One M8. What does it mean?
    By HouseDog1 in forum Android 4.4 KitKat
    Last Post: 11-29-2014, 02:54 AM
  2. message notifications and tones not playing
    By chris2707 in forum HTC One M8
    Last Post: 06-16-2014, 10:03 AM
  3. Widgets? Notifications on locked screen
    By drew_sf in forum Android 4.4 KitKat
    Last Post: 06-05-2014, 03:15 PM
  4. Any sort of toggle or widget to clear my notifications?
    By paisley99 in forum General Help and How To
    Last Post: 06-03-2014, 04:01 PM
  5. G2 - cloudmagic LED notification
    By jasonFTW in forum LG G2
    Last Post: 06-02-2014, 05:19 PM
