1. majdi suliman's Avatar
    If you are sick of your battery draining faster than others..
    What you do is..
    Hold home buttom and open the statistics, click downloaded
    Go to every offline game u have and force stop it and untick the show notification box.
    It works for me!
    You can see on the pic that surprisingly only used 4% on 58 mins. Internet browsing and texting 41 mins active..
    This is great!
    Attached Thumbnails battery drainage solution !!!(I found it!)-screenshot_2014-06-07-19-55-11.jpg
    06-07-2014 11:02 AM
  2. Golfdriver97's Avatar
    Thanks for sharing. Glad that worked for you.
    06-08-2014 11:05 AM
  3. Martin Tashi's Avatar
    Also if you deactivate auto sync.
    06-08-2014 11:34 AM
  1. Default Lockscreen Wallpaper-anyone have it?
    By Jay20 in forum Samsung Galaxy S5
    Last Post: 06-11-2016, 07:36 AM
  2. Battery stops charging when screen times out after update to 4.2.2
    By Downlander in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-16-2014, 09:10 PM
  3. Missing Buttons On Keyboard / Layout Changed - How Do I Get It Back?
    By tomhouy in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 06-12-2014, 07:51 AM
  4. Samsung S4: Battery Drain + Unplayable music files?
    By Wesley8631 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-09-2014, 12:09 AM
  5. Galaxy S4 with extended battery
    By thereressa in forum Samsung Galaxy S4
    Last Post: 06-07-2014, 10:52 AM
