1. Gary_Berg's Avatar
    I've got a US Galaxy S4 that has an 8Gb microSD card in it. It's getting full and I'd like to replace it with a 32Gb one. I had thought to turn the phone off, extract the old card, and copy everything from the old card to the new one (out of the box) on a Windows PC. Will that work, or are there other things that need to get done? I'm trying to avoid worrying about which apps are set to write to folders on the microSD card getting confused by seeing the blank card there.
    Destination card is a Sandisk Ultra.
    Thanks,
    Gary
    06-12-2014 12:55 PM
  2. B. Diddy's Avatar
    I think that would work, but I've never tried it myself. When you remove the old card, make sure you unmount it first in the Settings>Storage menu.
    06-12-2014 01:06 PM
  3. abcomputin's Avatar
    It may not matter, but, after unmounting and removing the old card, I would insert and mount the new one and let the phone format it. Then unmount and remove it and do your copy to it on your Win PC.
    06-12-2014 04:17 PM
  4. Gary_Berg's Avatar
    I was planning to shut down the phone before I removed the card. I guess I'm best off formatting the card in the device. If I do that I'll have to check the apps which write to the card to make sure they remember to do so.
    If I shut down to swap the card to I still need to eject it in Storage in Settings?
    06-12-2014 07:49 PM
  5. B. Diddy's Avatar
    I'm not sure if there's any problem with shutting down and then removing the card. If you want to be completely safe, unmount first, then shut down, then remove the card.
    06-12-2014 08:44 PM
  1. What is new in KitKat for us really?
    By shaungilmer in forum Samsung Galaxy Note 2
    Last Post: 06-13-2014, 03:06 AM
  2. Down 70% in under 5 hours...
    By manni1to in forum HTC One M8
    Last Post: 06-12-2014, 12:58 PM
  3. Help on Rooting or downgrading my At&t galaxy S4 4.4.2 KitKat
    By superhalder in forum Android 4.4 KitKat
    Last Post: 06-12-2014, 12:47 PM
  4. Samsung S4 Magnetic Sensor NOT Working?
    By Jordan Britt in forum Samsung Galaxy S4 Google Edition
    Last Post: 06-12-2014, 12:22 PM
  5. Htc One M8 Asia in Europe
    By Majestix in forum HTC One M8
    Last Post: 06-12-2014, 12:12 PM
