Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
  1. Thread Author  Thread Author    #26
    Jasonlwe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [HELP] My S4 charges very slowly, battery or charger problem?
    Guys, the problem is solved. It was definitely the cable's problem. I went to the dealer again to try it out and turn's out that the first time i was trying the new cable, it wasn't plugged in correctly which turned into USB charging. Thanks everyone.
    dpham00 and Jeriann2001 like this.
  2. #27
    dpham00's Avatar
    Posts
    Global Posts
    24,793 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Jasonlwe View Post
    Glad you got it resolved
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
  3. #28
    Jeriann2001's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just saw your post in "Trending" which caught my eye as I have been working on the same problem since yesterday even bought and tried 3 different chargers. I have also searched and found this is common. Now I'm wondering if an update caused this.
  4. #29
    Tabbiel1989's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I know with mine if the cable cord is very long it takes a lot longer for me to charge. I have a dock stand I use for charging and it charges so much faster.
  5. #30
    Melba Leary's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    All I had to do is remove the battery while powered on, leave off for about minute or so and now I no longer have slow charging issue. Works perfectly now. Prior to doing that make sure there are no apps running in background since that alone can sometimes cause the issue as well.
  6. #31
    bill gardner's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hi. I was viewing this thread and I have a question about the battery widget. If you set it up to run every minute, won't that consume more battery power?
  1. How do I make my S5 look more sexy?
    By Bayarea13 in forum Samsung Galaxy S5
    Last Post: 06-18-2014, 12:45 AM
  2. Wi-Fi problems!
    By LightaDroid in forum Google Nexus 5
    Last Post: 06-13-2014, 11:25 AM
  3. Be prepared to.. Lose reception or have a dropped call or two.
    By Cnorris92 in forum General News & Discussion
    Last Post: 06-13-2014, 11:14 AM
  4. Help me out?
    By RespectCheese21 in forum Android Apps
    Last Post: 06-13-2014, 10:38 AM
  5. NAS, can I connect my tablet to my has?
    By MrDerfdog in forum Other OS's and Devices
    Last Post: 06-13-2014, 09:41 AM
