12-05-2014 09:04 AM
31 12
tools
  1. Jasonlwe's Avatar
    Hey everyone, so basically my s4 started to charge very slowly recently and I think there could be two possibilities , either problem with the battery or the charger or both.
    1. I think it's the battery because I always charge my battery while calling my girlfriend. And by always, I mean ALWAYS, 90% of the time.
    2. I think it might be the charger or cable because I'm using an iPad charger and i guess that might damage the cable?
    This problem only came up recently all of a sudden. Can someone please help up? What should I do? What's the problem?
    06-13-2014 06:59 AM
  2. Paul627g's Avatar
    My opinion I would look at the possibility of a battery going bad. Overcharging before the battery is depleted or living on the cord could lead to early failure of the battery. You could use a few different apps available from Google Play that will give you a better idea if its a bad battery by telling you more in depth details health speaking on you battery.
    As for the iPad charger, nah.. I've used Blackberry, Palm and varying OEM's chargers and cords over the years and yes even my daughter uses her old iPhone charger adapter on her Android phone with no obvious signs of damage. Maybe she's been lucky but I doubt it for the amount of time shes been doing it.
    06-13-2014 07:28 AM
  3. dpham00's Avatar
    Any quality cable and charger won't cause damage. The phone will only take whatever power it needs.
    You can install battery monitor widget to set up battery monitoring and see what rate you are charging at to see if there is a problem.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    06-13-2014 08:01 AM
  4. Jasonlwe's Avatar
    Any suggested apps?
    06-13-2014 08:19 AM
  5. Jasonlwe's Avatar
    So do you think it could be the battery problem? I've been charging it for like 3 hours from now and if finally charged to 30%. I didn't even touch it.
    06-13-2014 08:21 AM
  6. dpham00's Avatar
    Any suggested apps?
    Have you tried battery monitor widget which I mentioned in post 3?
    06-13-2014 08:23 AM
  7. dpham00's Avatar
    Log with battery monitor widget while charging and post screen shot. It could be a charger or cable problem.
    06-13-2014 08:28 AM
  8. Jasonlwe's Avatar
    http://img.tapatalk.com/d/14/06/13/e8uvygeh.jpg
    Yes, I've installed it. What information can I get from it and what would show me my battery has a problem?
    06-13-2014 08:40 AM
  9. dpham00's Avatar
    Set up battery logging every minute, then let it run for an hour or so, and check on the chart similar to what I posted. My guess is that the charging rate is very slow, but a log could confirm.
    In the app :
    Settings - battery monitoring - monitoring intervals - every minute (accurate but may consume more data)
    06-13-2014 08:44 AM
  10. Jasonlwe's Avatar
    Here are the results
    Sent from my GT-I9500 using AC Forums mobile app
    Attached Thumbnails [HELP] My S4 charges very slowly, battery or charger problem?-1402669259515.jpg   [HELP] My S4 charges very slowly, battery or charger problem?-1402669275989.jpg
    06-13-2014 09:21 AM
  11. Jasonlwe's Avatar
    In the app :
    The %/h even got to negative while i was posting the screenshots with my phone.
    06-13-2014 09:28 AM
  12. dpham00's Avatar
    Can you tap on the %h and retake the screen shot? It should give you "ma" similar to my screen shot
    06-13-2014 09:53 AM
  13. Jasonlwe's Avatar
    Attached Thumbnails [HELP] My S4 charges very slowly, battery or charger problem?-1402671850367.jpg   [HELP] My S4 charges very slowly, battery or charger problem?-1402671863620.jpg
    06-13-2014 10:04 AM
  14. dpham00's Avatar
    Certainly slow charging rate. I would suggest trying another quality charging cable and charger.
    06-13-2014 10:08 AM
  15. Jasonlwe's Avatar
    Newest shot , there was a sudden increase then decreasing in the milli ampere
    Attached Thumbnails [HELP] My S4 charges very slowly, battery or charger problem?-1402672792287.jpg
    06-13-2014 10:20 AM
  16. Jasonlwe's Avatar
    Do you think this could also be caused by battery problems or are you sure that it's the cable and charger problems? I think it can't be the charger's problem since when I use the cable with my powerbank, it's the same situation. So the cable?
    06-13-2014 10:32 AM
  17. dpham00's Avatar
    Something else to test is to let it monitor when not charging and see what battery consumption is.
    Your charging rate seems odd.
    Also I would clean the charging contacts. Use a toothbrush and rubbing alcohol.
    06-13-2014 11:51 AM
  18. Kolten Nay's Avatar
    It could be the fact that you aren't using the original charger that came with it. The original charger works with Qualcomm quick charge, and when I charge my phone with any other charger, you can definetly see the difference. Hope this helped.
    Posted via My Ever-Bloated S4
    06-13-2014 12:20 PM
  19. mjs416's Avatar
    Nearly impossible to tell if you have a bad battery or charger unless you are able to have a spare of each and swap them out.
    A way to look at it is if you have a 1500 mAH charger - that means it can supply enough power to charge a 1500 mA battery in 1 hour. You need to check the charging rate of the charger and the amp rating of the battery.
    06-13-2014 01:01 PM
  20. Jasonlwe's Avatar
    Here's the discharging rate without any interference
    Attached Thumbnails [HELP] My S4 charges very slowly, battery or charger problem?-1402703637000.jpg
    06-13-2014 06:54 PM
  21. Jasonlwe's Avatar
    I doubt that it is the charger's problem since the charging rate is also very slow with my power bank.
    06-13-2014 06:55 PM
  22. Jasonlwe's Avatar
    So basically, I went over to a dealer and tried a brand new charger and cable. The data is shown in the attachment. @dpham00, what do you think?
    Attached Thumbnails [HELP] My S4 charges very slowly, battery or charger problem?-1402717689352.jpg
    06-13-2014 10:48 PM
  23. dpham00's Avatar
    Discharge rate seems to be acceptable
    Sent from my XT1028 using Tapatalk
    06-13-2014 11:53 PM
  24. dpham00's Avatar
    The s4 comes with a 2 amp charger stock, assuming genuine Samsung . But regardless, the charging rate is going so over the map. If I had to guess, I would think something is wrong with the charging port.
    Have you tried to clean it yet?
    06-13-2014 11:57 PM
  25. Jasonlwe's Avatar
    I've cleaned the battery contacts but not the port yet. How do you clean the port ? @@
    Btw, when it was charged using the charger at the locator. The mode was USB charging ( might be because of not plugging it correctly? )
    I think if the plug was plugged in the amp would be higher. Don't you think so ?
    06-14-2014 12:32 AM
31 12
  1. How do I make my S5 look more sexy?
    By Bayarea13 in forum Samsung Galaxy S5
    Last Post: 06-17-2014, 11:45 PM
  2. Wi-Fi problems!
    By LightaDroid in forum Google Nexus 5
    Last Post: 06-13-2014, 10:25 AM
  3. Be prepared to.. Lose reception or have a dropped call or two.
    By Cnorris92 in forum General News & Discussion
    Last Post: 06-13-2014, 10:14 AM
  4. Help me out?
    By RespectCheese21 in forum Android Apps
    Last Post: 06-13-2014, 09:38 AM
  5. NAS, can I connect my tablet to my has?
    By MrDerfdog in forum Other OS's and Devices
    Last Post: 06-13-2014, 08:41 AM
