Results 1 to 2 of 2
    Default Reset: Hard or Soft
    How do you do a soft reset and a hard reset if that does not work? Thanks!
  2. #2
    Default Re: Reset: Hard or Soft
    It depends on what you mean by soft and hard reset. Soft reset typically means a simple reboot--i.e., powering the phone down completely, then turning it on again. As long as you saved any data that you were working on before the reboot, no data will be lost.
    A hard reset typically means a full factory data reset, which wipes the phone. This can be achieved from within the Settings>Backup & reset menu. If you're unable to get there, you can also boot into Recovery and do it there as well: Reset: Samsung Galaxy S 4 | T-Mobile Support
  1. [HELP] My S4 charges very slowly, battery or charger problem?
    By Jasonlwe in forum Samsung Galaxy S4
    Last Post: 12-05-2014, 10:04 AM
  2. Replies: 4
    Last Post: 06-15-2014, 09:50 PM
  3. Which mobile is better Iphone 5 or Samsung galaxy S4?
    By ChristopherRParker in forum Samsung Galaxy S5
    Last Post: 06-14-2014, 05:02 AM
  4. Beeps every 15 seconds or so
    By Jamesiv1 in forum Samsung Galaxy S4 Mini
    Last Post: 06-13-2014, 11:55 AM
  5. Be prepared to.. Lose reception or have a dropped call or two.
    By Cnorris92 in forum General News & Discussion
    Last Post: 06-13-2014, 11:14 AM
