1. ndira's Avatar
    I can't wait until 4.4.3 arrives. I'm sick and tired of 4.4.2 bugs. It drains my battery so fast, it goes from 100% to, 30% in less than two hours.
    Sent from my GT-I9500 using AC Forums mobile app
    06-15-2014 05:02 AM
  2. ngerber999's Avatar
    Have you looked at your battery stats? I was having similar battery drain and found it to be Google+ keeping my S4 awake.
    Sent from my SCH-I545 using Tapatalk
    06-15-2014 08:22 AM
  3. toober's Avatar
    Mine was draining very fast after the KitKat update until I cleared the system cache. Now, it has been unplugged for 13 h 44m and has only used 49%. I found the instructions on here to boot into recovery and clear the cache. I hope this helps you.
    06-15-2014 02:53 PM
  1. HDMI output not working after Kit Kat Update
    Last Post: 12-22-2015, 01:47 AM
  2. Chromecast bug on Galaxy Tab 4 10.1
    By John Wiskowski in forum Samsung Galaxy Tab4 10.1
    Last Post: 09-08-2014, 12:33 PM
  3. Canada Roaming Issues after Kit-Kat
    By rcw119 in forum Droid RAZR MAXX HD
    Last Post: 08-06-2014, 12:31 PM
  4. Kitt kat batter life issues
    Last Post: 06-14-2014, 12:57 PM
  5. HDMI output not working since Kit Kat update
    By skate79 in forum Droid RAZR MAXX HD
    Last Post: 06-14-2014, 11:58 AM
