Results 1 to 2 of 2
    Default Power button instantly locks and PIN lock
    Hello,
    after some update I have an issue with some S4 in our company.
    We have not change any policy, "Power button instantly locks" has been disabled but this setting seems to be ignored.
    So, every time that device goes in standby or powerbutton is click, screen lock appear, despite settings are to ask pin after 14 minutes.
    Anyone as the same problem? (... and a fix) do you know if it possible to unistall this update (don't suggest to factory reset - I know about it..., )
    Thanks a lot to all
    Giovanni Rastelli
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Default Re: Power button instantly locks and PIN lock
    Quote Originally Posted by Giovanni Rastelli View Post
    Hello,
    Thanks a lot to all
    Giovanni Rastelli
    Well, this seems weird have you tried doing a soft factory rest !! This reset will not remove your data or ..... but what it will do is rest all the settings back to the time when you have purchased your device. See if that works out otherwise I am afraid but you need to do a factory reset !
  1. Replies: 1
    Last Post: 07-08-2014, 07:01 PM
  2. Replies: 11
    Last Post: 07-03-2014, 06:11 PM
  3. 2 questions, and one thank you note
    By Lions2 in forum Virgin Mobile Optimus V
    Last Post: 06-30-2014, 11:39 PM
  4. SGS4 home button stops doing it's thing: hardware or software
    By lngndvs in forum T-Mobile Samsung Galaxy S4
    Last Post: 06-30-2014, 04:10 AM
