1. JohnnyGui's Avatar
    Good day all,
    For some reason my S Planner widget on my homescreen only shows events but not tasks created in S Planner.
    When I create a task in S Planner it's not visible in the widget but only in the S Planner app itself. I enabled the option in S Planner to view all of my calendars and tasks. Tapping the synchronize option a hundred times also doesn't work.
    Is this normal behavior for the widget or is there something I'm missing?
    Here's the widget that I'm talking about (marked with a red square).
    07-01-2014 12:38 PM
  2. JohnnyGui's Avatar
    Anyone?
    07-06-2014 11:09 AM
  1. problem with navigation bar
    Last Post: 03-09-2015, 07:56 PM
  2. Safestrap issues
    By Eric Ruiz1 in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 08-20-2014, 07:37 PM
  3. Weather Widget
    By Ricky Hughes in forum Samsung Galaxy S4
    Last Post: 07-04-2014, 06:41 PM
  4. Handcent and MMS with multiple contacts avatar
    By gyoung345 in forum Android Apps
    Last Post: 07-01-2014, 10:40 AM
  5. Problems with 3rd Party Messaging Apps
    By Nekoxii in forum Ask a Question
    Last Post: 07-01-2014, 09:50 AM
