04-01-2017 06:06 PM
98 123 ...
tools
  1. nickkpoon's Avatar
    So my Galaxy S4 turned off randomly today during charge. I attempted turning it back on via the power button and it would not respond.
    Then I tried taking out the battery and replacing it, the device vibrates with the Galaxy S4 logo showing up for about a couple seconds, then the screen goes blank again.
    I even tried placing a battery from a different S4 - still doesn't work.
    Anybody know what's wrong with my device?
    qwert11 likes this.
    07-17-2014 09:15 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! How old was the other battery you tried? It'd be ideal to try a brand new replacement battery--but if the one you tried is known to be reliable, that probably rules out the battery as the problem.
    Try removing the SD card and booting up again. A corrupt SD card can cause problems.
    qwert11 likes this.
    07-17-2014 10:37 PM
  3. nickkpoon's Avatar
    Hello Diddy, thanks for the welcome!
    Both batteries are around a year old.
    Just tried removing the sd card, didn't help with the problem. Also I have tried getting into downloader and recovery mode, still no response.
    I can get into download and recovery mode via inserting the battery, though.
    Such a strange problem. The device has been running with a flashed rom and rooted, and has no problems leading up until today's failure.
    07-17-2014 11:25 PM
  4. B. Diddy's Avatar
    Try booting into Safe Mode, which disables all 3rd party apps. If the problem stops, then something you've installed is raising heck. If the problem persists, then something is wrong with either your hardware or firmware. Steps for Safe Mode at the bottom of this article: Reset: Samsung Galaxy S 4 | T-Mobile Support
    07-17-2014 11:29 PM
  5. nickkpoon's Avatar
    Tried safe mode, could not get in.
    Screen shut off after a couple seconds as usual. Is the device hard bricked? What might have caused this problem?
    07-18-2014 12:57 AM
  6. B. Diddy's Avatar
    How far along did you get in the Safe Mode boot process? Did it actually reboot into Safe Mode, then shut off? Or did it not even get to reboot?
    How old is your phone? If it's still within warranty, it's probably time to talk to Samsung.
    07-18-2014 02:22 AM
  7. nickkpoon's Avatar
    It didn't even get into safe mode.
    However, it did get into recovery mode or download mode, ONLY when I replace the battery to turn it on. It would show the screens for the respective modes, but turns off promptly in a few seconds.
    I believe that my phone is still under warranty, however it has been rooted and flashed rom. I would also like to retain the data that I have on my phone, that's why I want to attempt to fix it before resorting to claiming the warranty.
    07-18-2014 01:02 PM
  8. dom2114's Avatar
    Just wanted to add to the thread that I'm having the absolute identical issue.
    Only way to get any life out of the phone is to remove and reinsert the battery. It turns out for about 2/3 seconds then dies. Holding down the various combinations of buttons to get into recovery/bootloader etc. does work, but again, the phone dies after 2/3 seconds.
    Phone has been working perfectly for over a year, is on Verizon, MDK baseband and has been running a custom ROM the entire time.
    If anyone has any advice on how to fix I'd be grateful. At this point, I'd just like to wipe the phone to remove any pics/files etc. so I can return for a replacement.
    09-07-2014 08:48 AM
  9. RMatSLU's Avatar
    Just happened to me this week. I had to get a replacement phone. Most of everything transferred as it was backed up but I had a bunch of pictures saved in created folders and these were not on the SD card.
    Has anyone figured out a fix? I don't want to send the damaged phone back yet as I'd love to get these pics. I have 3 weeks to return the phone back to tmobile. Thanks.
    09-25-2014 02:21 PM
  10. dharmil's Avatar
    I am having the same issue with my phone. I have a Att samsung GS4.
    When i turn the phone on the samsung screen comes on and than just goes blank. When i try to go into safemode or recovery it does the same thing. The phone loads into the respective modes and than screen goes black before I can do anything.
    09-27-2014 07:30 PM
  11. dharmil's Avatar
    I found the solution to the problem. You guys will have to open the phone and clean out the power switch. The problem is that the power switch its stuck or pushed down permanently, this was a known issue in the S3 guess they never fixed it in S4. It took me 10 mines to take it apart and clean it and now the phone works perfect!
    09-27-2014 07:57 PM
  12. Herbas's Avatar
    dharmil, how easy is that procedure? I have the same problem and i would have to get to court if o want samsung to solve this problem for free here in my country, since it's been more than a year of purchase.
    09-29-2014 08:19 PM
  13. scarmona's Avatar
    This started happening today out of the blue to me, I did open the phone to some extent and cleaned as best as I could the power button with satisfactory results. But I still think the job was partially done and we could benefit from your experience, can you post a guide with the steps you followed to clean your phone?
    Thanks!
    Sent from my SM-P600 using Tapatalk
    qwert11 likes this.
    10-28-2014 05:37 PM
  14. Carlos Torres Vazquez's Avatar
    NOPE! I know what's wrong everyone. It is the power button. it is stuck in. therefore when you take out the batter and put it back it, the button is already pushed in causing it to turn on by itself. But since it turns on the button is still pushed in causing it to turn off immediately. SOLUTION: take the phone and put it sideways where the power button is facing down on a table or some flat surface and don't slam it! but lightly hit it maybe a couple of times and the button will come unstuck. The phone should turn on by itself but the button isn't stuck so it will turn on perfectly fine. I am having the same problem right now actually and it is very frustrating but if do this then it should work.
    11-18-2014 05:54 PM
  15. Syafiq Boy's Avatar
    me too>>>!!!!
    12-03-2014 04:21 AM
  16. Syafiq Boy's Avatar
    hi i have a samsung galaxy s4. I just put the batteries into mobile phones and it presented itself .There is anyone who can help me for this problem? he only lived a short while before it closed and it came back to life and it closed again and continued .i hope somebody can help me in this problem.
    12-03-2014 04:31 AM
  17. Bri Seepersad's Avatar
    Omg thank you this worked for me
    12-09-2014 11:44 PM
  18. Kenneth Woodley Jr's Avatar
    The same thing happened to me out of no where do ii need a new battery?
    12-16-2014 05:21 PM
  19. Martin Kosicky's Avatar
    I have the same problem. I don't have SD card. The phone is a few months old.
    12-21-2014 03:54 PM
  20. Cybertoy's Avatar
    this worked! Thanks!
    12-22-2014 03:23 AM
  21. Fridder S's Avatar
    My phone is doing the same ****. How can I clean this power button? I have my phone opened up, and the button looks mint. Everything around it (on the board) is mint. I plugged just the screen in and it does the same thing when I put the battery in, even though the button isn't even touching anything. I tried pulling the button out slightly with tweezers, and it still doesn't help.
    edit.. I ripped the button off the board lmao all is working good now
    rickyc19 likes this.
    12-26-2014 12:28 PM
  22. bhefty7's Avatar
    UPDATE: I created an account just to thank you! This solution worked perfectly for me and I no longer will have to tear my phone apart. I already ordered a new battery but hey that isn't the end of the world.
    THANK YOU
    01-07-2015 09:02 AM
  23. d.k2's Avatar
    Just open the phone and wash with thinner include power button also.
    01-07-2015 01:18 PM
  24. RudyGT's Avatar
    i too am having a problem with my phone doing exactly this, has anyone found information about the power switch?
    i appear to be getting continuity with the switch not depressed across the 2 leads, however i cant get voltage, from what i can
    tell by using 2 hands and poor leads at the power switch open or close.
    i cracked my glass after its entire time in a case by trying to press the home + volume + power key + inserting the battery, so i cant replace it easy.
    01-07-2015 04:05 PM
  25. RudyGT's Avatar
    so i just want to give my story here...
    continued from the above post, my switch felt good made a nice click sound and everything else.
    if i plugged it in to power it did nothing, with or without a battery. if i left the battery in it,
    it drained the battery. the sprint store said my battery was dead. the battery isnt dead, deformed or anything.
    so.. after trying to find a way to test the switch i gave up, ripped the switch off.
    and my phone works..
    you would think one would be happy to have a working phone, but instead i was disgusted by what seems to be
    a common defective switch across the s3 and s4..
    and to help anyone else out, to turn your phone on, press and hold the volume down button, connect it to a computer
    it will enter download mode release the button, but instead of doing that just press down on the volume again
    to reboot.. then your phone is on.
    Gang Warily likes this.
    01-10-2015 12:26 AM
98 123 ...
  1. Replies: 9
    Last Post: 07-09-2015, 01:49 PM
  2. Samsung Galaxy s4 for Verizon
    By skipatrol in forum Marketplace Archive
    Last Post: 07-26-2014, 09:33 PM
  3. Knock Knock Code turns off after restart
    By godsidekurt in forum LG G3
    Last Post: 07-22-2014, 08:57 PM
  4. How do I access the clipboard on my HTC ة8?
    By AC Question in forum HTC One M8
    Last Post: 07-17-2014, 09:53 PM
  5. picture real dark on camera
    By mesocyclone30 in forum HTC One M7
    Last Post: 07-17-2014, 09:14 PM
