Results 1 to 5 of 5
    Happy_Knight's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Capacitive menu constantly flickers (serious issue)
    Oi well I'm not sure what's going on with my phone, I've had it for about- hm, since early July- this isnt my first galaxy s4 phone however, I had to get it replaced because the phone would give me invisible notifications - which made my phone endlessly vibrate , and also had the very same issue that the current phone I'm using has.
    Anyway, in regards of the current phone I own , my phone has the tendency to flicker the capacitive menu out of the blue. I just unlock the phone and my phone just starts flickering/blinking the capacitive menu continuously, the issue lasts for about several hours to about 2 days. I don't even have to touch the screen or buttons- it just does it without any form of manipulation. It occurs on every app/thing i use by the way- so yeah it affects my home screen- making the phone almost unusable when you're trying to type or touch the screen properly. I don't know what to really do with my phone, I've tried resetting it, leaving it alone for a while, clearly factory resetting/getting a new phone did not work either. I'm not sure if it's the card inside of it that's broken or I just don't have my luck with this particular phone. I would really appreciate a response for this .
  2. Thread Author  Thread Author    #2
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Capacitive menu constantly flickers (serious issue)
    i know y'all looking and aint replying
    i need help babies
  3. #3
    osvanberg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Moisture damage would be my bet!
    Skickat från min GT-I9195 via Tapatalk
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What do you even mean? I never even put this phone in the water are you even reading this correctly ?
  5. #5
    osvanberg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Happy_Knight View Post
    An damp environment is sometimes enough to mess a phone up. Just saying....... Can happen pretty randomly on phones.
  1. WiFi issue HELPP!! PLEASE!
    By PxuLL in forum OnePlus One
    Last Post: 08-05-2014, 07:28 PM
  2. Replies: 10
    Last Post: 08-05-2014, 07:10 PM
  3. Sprint Galaxy S II Epic 4G Touch Issue-Need Help
    By Josephine Lozada in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 08-04-2014, 04:34 PM
  4. Verizon G900VVRU1ANE9 reboot issues?
    By mjcecil in forum Samsung Galaxy S5
    Last Post: 08-04-2014, 04:18 PM
  5. Replies: 0
    Last Post: 08-04-2014, 04:05 PM
