E Edible Walrus Well-known member Aug 30, 2013 393 0 0 Visit site Aug 22, 2014 #1 Right so my phone has another thing wrong with it. My signal unexplainably dies completely and doesn't return until I restart. Anyone? Posted via Android Central App
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,541 4,675 113 Visit site Aug 22, 2014 #2 Voice or data or both? Maybe a bad SIM? Check with your wireless provider and see if you can try a replacement SIM.
E Edible Walrus Well-known member Aug 30, 2013 393 0 0 Visit site Aug 22, 2014 #3 Both. My SIM has already been replaced because I kept losing data which cured it, but now after almost six months I have this problem Signal drops to zero bars but I still have the carrier's name in the notification tray Posted via Android Central App
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,541 4,675 113 Visit site Aug 22, 2014 #4 Maybe a problem with the phone's antenna? Can you identify any common factors that are associated with the signal dropout? Like location, position of the phone, squeezing it in a funny way, etc.?
E Edible Walrus Well-known member Aug 30, 2013 393 0 0 Visit site Aug 22, 2014 #5 Currently unknown. It will just drop, but keep the carrier's name. Stuff has stopped working on this phone faster than I can type this post Posted via Android Central App
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,541 4,675 113 Visit site Aug 22, 2014 #6 Have you already done a system cache partition wipe, or a factory reset?
