Results 1 to 1 of 1
    JohnnyGui's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default TWO Android systems draining battery??
    Good day to you all,
    Recently after a small Android update (still having version 4.4.2) I noticed the battery was draining faster than it used to. Before that, it was consuming roughly 1% per hour in idle. This has changed now to 3-5% per hour. Looking at the battery info I noticed the Android system was the biggest batterysucker here. Not only that, there are even TWO Android systems shown and I began to think there's something wrong here
    Also looking at the wakelocks shows that my phone is barely able to get into sleepmode.
    Before posting this thread I have literally tried every option to see if it could lessen the battery consumption:
    - Disabled Google location reporting services
    - Disabled GPS
    - Disabled Google sync
    - Disable Wifi when in Sleep mode
    - I don't use Google Now so it's disabled
    - Widen the Facebook refresh intervals to 4 hours
    - Wiped the cache partition
    None of the above worked and I started to think that the second Android system here might be the cause.
    Should there be a second Android system consuming battery? What could be the problem here??
