Hello
I own Samsung Galaxy S4 I9500 and it is rooted. I recently purchased a class 10 Sandisk Micro SD card with 64 GB capacity. I was very happy that I did but my happiness did not last long when I have come to know that 3rd party apps do not have write permission in Kitkat. After some research I was successful to make the SD card writable to 3rd party apps by modifying the permissions.xml file.
Everything seems to be fine at this time but it was not actually. The SD card when seen under storage in settings would show me that it is mounted with 62.5 GB capacity and 60 GB free. But when I try to browse the files in SD card, there are nothing. Apps saved in SD card do not open and I am also unable to capture images from camera to SD card storage.
I thought may be unmounting the SD card and mounting it back would work and it worked but after a while the same problem. My device shows that it has mounted an SD card but cannot access anything saved in it. So, I have to unmount and mount SD card every time and this is very much annoying.:'(
Any help regarding this would be greatly appreciated.
Thanks you for your time.
