I have a galaxy s4 and have had battery issues with it since I got it. The time it took me to sign up for this site, my battery has drained 6%. It lasts maybe an hour of screen time in general. Now, you might be thinking there's background apps sucking away the battery, but I've tried everything. I factory reset, clear cache partition, disabled all the bloatware, installed gsam to monitor the battery and nothing is unusual. No apps with excessive wakelocks, no apps with high cpu usage, just nothing. After using it down to 10%, the screen had the highest drain at 70% with maybe about 50% brightness and android os had the second most at just 10%. Been typing this with the brightness all the way down and battery has drained another 7% in under 10mins. Verizon sent me a replacement battery, same problem. Sent it into them for diagnosis, they said it worked fine for them. I have no idea what's wrong with it and I've about had it. The antutu benchmark drains the battery completely in about 20mins. Charge time is pretty fast, haven't experienced any slowdown in charge time. Any help?
Edit: Just installed a battery widget and it says the battery discharge is just under 2000ma per hour. The per app discharge leaves 1600ma unaccounted for, strange.
