Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By MisterBid
    3rdpig's Avatar
    Posts
    Global Posts
    369 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Problem with Otterbox volume controls
    I just got an Otterbox Defender and I can't get the volume controls to work. It seems to fit good, and I've taken it apart and put it back together several times. Sometimes the volume down will work once or twice then quit.
    Any suggestions?
  2. #2
    MisterBid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Problem with Otterbox volume controls
    Have you checked the little flaps that are on the inside that control it? They could possibly be to small I would contact otterbox, if that's the problem they will send you they new silicone cover or whatever the material is free of charge and free shipping. Keep me updated if possible. Thanks
    sparker04 likes this.
  3. #3
    sparker04's Avatar
    Posts
    Global Posts
    182 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 3rdpig View Post
    Any suggestions?
    It just seems like a defect. It shouldn't interfere with any buttons you have. Ask for a new one and they shouldn't give you too many problems about it.
  4. #4
    droidsexy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I purchased a case and the volume buttons are hollow so in other words the case button didn't make contact with the phone button when pressed. It seemed to be a problem with the case mold as every other case at that store had the same problem. I cannot remember the brand but that could be it. I have a spigen now (the one with the clear back) and I absolutely love it. :-)
  1. HTC ONE M8 Problem with mobile hotspot
    By Brunnaso in forum HTC One M8
    Last Post: 10-17-2016, 08:33 AM
  2. Lens Blur not working with Google Camera on Razr Maxx HD
    By Hunter Wilson in forum Droid RAZR MAXX HD
    Last Post: 07-08-2014, 10:35 AM
  3. Moved photos to SD card problem
    By backfat1982 in forum Samsung Galaxy S4
    Last Post: 05-18-2014, 02:33 AM
  4. Automatic Comment Control for Instagram
    By Dan Rice1 in forum Android App Inventor
    Last Post: 05-17-2014, 06:10 PM
