1. felloffthetruck's Avatar
    Anyone have any idea?
    I'm waiting with bated breath and hate to order this type of item from an eBay seller.
    05-20-2014 04:55 PM
  2. felloffthetruck's Avatar
    Any shopandroid people out there?
    05-20-2014 10:01 PM
  3. pchrist11's Avatar
    I am also very interested in this cover. Will order as soon as they are available.
    05-21-2014 07:43 AM
  4. AZbear's Avatar
    I want one very baldy.
    05-21-2014 07:14 PM
  5. cabinets#IM's Avatar
    Got mine in today. Ordered from eBay. OEM Samsung back. White. Not much bulk at all and charges pretty quickly.
    05-21-2014 08:05 PM
  6. jschu22's Avatar
    Is the Samsung printed or the chrome inlay?
    05-26-2014 11:21 PM
  7. gmurphy0487's Avatar
    My local att store has them in stock now. Might want to check yours.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    05-30-2014 07:44 PM
  8. gmurphy0487's Avatar
    Double post. Oops....
    05-30-2014 07:44 PM
  9. AZbear's Avatar
    Thanks for the heads up. Just ordered online for store pickup tomorrow
    05-30-2014 09:59 PM
  10. felloffthetruck's Avatar
    Do they have the AT&T logo on them?
    05-31-2014 04:35 PM
  11. AZbear's Avatar
    Nope, no AT&T logo. Just says Samsung. $37.90 with tax.
    I did have to endure a 10 minute sales pitch on the new plans and such from the sales rep which I did not enjoy.
    05-31-2014 06:39 PM
  12. ask_me_again_11's Avatar
    Good catch! Do you know if this would be compatible with a VZW S5, or is there some exclusivity?
    06-01-2014 01:00 PM
  13. gmurphy0487's Avatar
    I see no reason why it wouldnt work with the VZW version seeing that this is not an AT&T branded accessory. But if for any reason it didn't work, put it back in the package and return it. I have never had a problem with returns at my local AT&T corporate store.
    06-01-2014 06:01 PM
  14. Canalla's Avatar
    I just received notification from shopandroid that my samsung wireless cover & charging pad has been shipped.
    I ordered both on mother's day.
    06-02-2014 11:56 AM
  15. Shawn0813's Avatar
    I bought mine at a local Verizon store, they had a bundle deal for 80 dollars that included the samsung charger as well.
    06-08-2014 11:19 AM
  16. kchinger's Avatar
    I just got a 50% off coupon for the Samsung store for registering with them after getting my new phone. I was considering getting a wireless back and buying a charging pad, but the back is only $30 from Samsung, which makes it $15 with the coupon, I doubt it's cheaper anywhere else. Hopefully it comes back in stock soon.
    Is there a charging pad people recommend, or should I just look for a good, well reviewed one? Do they all stop at 100% charge? I want one I can just set it on overnight and not worry about.
    06-11-2014 01:18 PM
  17. Shawn0813's Avatar
    I have this charging pad and it works great. It stops charging at 100% and is still 100% when I take it off the charger in the mornings. Wireless Charging Pad mini. And this is the case I got. Galaxy S 5 Wireless Charging S-View Flip Cover, Black
    06-11-2014 08:18 PM
  18. Blazer1234's Avatar
    Hello can anyone tell me if you can use this style or any style of Qi chargers with an Otterbox?
    06-12-2014 09:36 PM
  19. Eclipse2K's Avatar
    The charging coils that you insert in the stock cover would work. The OEM Charging Cover will not fit with the Otterbox or nearly any other case for that matter. The only case I have that works is the Samsung OEM Protective Case but it takes proper installation.
    Samsung Galaxy S5 (Verizon)
    06-13-2014 05:04 AM
  20. Cruzzer08's Avatar
    The White Wireless Charging Back is in stock right now on Samsung.com, has been for a couple weeks. I wasted a bunch of time waiting for the Samsung email on a Black back which I have still not received.
    I used my 50% off to get the Samsung Wireless Charging Pad Mini at the same time (it qualifies at 49.99), and then got an extra battery to break $50 for free shipping (that was another $7 in savings). It works great!! Battery is 100% in the morning and lasts all day.
    Charging Back + Mini Charging Pad+ Extra Battery = Total cost with 50% coupon was $58.82
    06-13-2014 11:50 AM
  21. Ted Kurkowski's Avatar
    FWIW Amazon promises the charging back by June 30.
    06-13-2014 02:52 PM
  22. Ted Kurkowski's Avatar
    Has anyone found a skin that fits the S5 with the Charging Back?
    06-13-2014 02:54 PM
  23. Eclipse2K's Avatar
    Or order it from here: http://www.bhphotovideo.com/c/buy/Sa...2FSID%2Fvb_ac=
    I got mine from there. A very reputable company so you won't regret it.
    06-15-2014 06:00 PM
  24. Eclipse2K's Avatar
    A case? If you're looking for a Bumper and are in the USA get a Belkin Grip Bumper.
    06-15-2014 06:00 PM
  1. The silence says a lot about this phone
    By doogald in forum Motorola Droid MAXX
    Last Post: 07-04-2014, 10:07 AM
  2. Kitkat roms without charging and brightness issues
    By Skip Furrer in forum Hisense
    Last Post: 06-24-2014, 03:18 PM
  3. Which stock firmware to unroot GT-I9505?
    By UrbanRich in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 06-14-2014, 04:49 PM
  4. Samsung adding Android apps support to Tizen?
    By JacksonEdwardHarrison in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-23-2014, 07:06 AM
