1. Maximun's Avatar
    How are friends ?, I open a new post to see if anyone could help ..
    I have read in several other places that the private option mode and S-Health stop working; after rooting or installing xposed? my question is:
    Private Mode and S-Health (They work after rooting)?
    Private Mode and S-Health (Not working after installing xposed)?
    I do not get the answer in any place ... I just want to root my device to remove a file; found in system; this drinking battery of my device.
    Greetings !!
    Model: G900H
    08-28-2014 08:12 PM
  2. AndroidProf's Avatar
    Yes, after rooting the phone does present problems with both private modes and S-Health. Though you can fix the S Health issues by making some changes in the build.prop. Just search for "How to fix S Health after root" on Google.
    08-29-2014 01:43 AM
  3. Maximun's Avatar
    Thank you very much friend; I was pretty confused about it but ready; all great .. This morning; I decided to root my phone; I had problem loading the cf-autoroot (cache) but finally I could complete the process .. Try resetting; the counter; with triangle away but had no success ...
    In the stock recovery:
    Model: G900H
    Binary: Custom (1)
    System Status: Official
    In triangle away:
    Model: G900H
    Binary: Custom (11)
    There should be only 1 ...
    I would like to leave it Official state to be aware of the major or minor updates. There will be some way to do it?
    Thank you, everyone ...
    08-29-2014 09:35 AM
  1. Must run Play installs twice!
    By pofadda in forum Android 4.4 KitKat
    Last Post: 09-07-2014, 03:30 PM
  2. When to Buy and When to upgrade
    By M120 in forum General News & Discussion
    Last Post: 08-31-2014, 07:34 PM
  3. Trouble with SDK
    Last Post: 08-28-2014, 08:08 PM
  4. Android tablet with active stylus
    Last Post: 08-28-2014, 07:39 PM
