Samsung Galaxy S5 Duos overheating problem!
Maq Attaq
66
Hi,
I am facing with an overheating problem on my Samsung Galaxy S5 Duos!
The phone was playing music for hours and hours without problem,also I was surfing the internet without problem,but it started to overheat a few days ago,even if I was surfing the internet nothing more!
It was on CM 12.1,so I decided to flash a new custom ROM (to update it to the Android 6.0),the Mokee.But the situation is almost the same!
So how can I test the phone to see what is the cause to the overheating problem?
And the Mokee ROM,has a big bug,when I try to make or receive a call,the phone restarts!
Please help me to solve these two problems,especially the overheating!
When I don't do anything on the phone,the temperature is normal,it overheats only if I do something,for example web surfing,but it still doesn't overheat if it plays music!
Thanks in advance!
Best regards!
There seems to be a number of issues with the Mokee ROM concerning the use of the dual sim feature and may explain the problems you are having. I would either wait for fix or change ROMs.
Dear ironass,thank you for replying to me!
But how can I solve the overheating problem?It persists on all ROM's!
Please tell me!
Thanks in advance!
Please tell me!
Thanks in advance!
Try running your phone in Safe Mode for about 6 hours and see if it still overheats.
Try Cooler Master app....closes down apps and prevents them from reopening unless you actually open them....worked for me when my battery got hot.
GermanAndroid2403
