Verizon S5 supports svlte, but not svdo or volte. Radio info inside.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
According to the fcc filing, the Verizon S5 supports svlte but not svdo or volte.
On the radio side, it supports gsm/EDGE /utms 850/1900. Lte support for bands 4 and 13. It is most likely a quad band gsm but fcc filing only deals with US bands.
I can post this for other carriers if this is something that people are interested in
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
jayochs
318
wait question.. volte I don't care about because that'll probably suck battery, but what's the other two?
Sent from my VS980 4G using Tapatalk
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Svlte =simultaneous voice and data over 4GLTE
Svdo =simultaneous voice and data over evdo (3g)
jayochs
318
I figured ok thanks. seems they're doing away with simultaneous 3g and voice. they're really only focusing on 4g now.
Raptor007
Trusted Member
Apr 18, 2010
4,906
58
Wasn't Verizon supposed to be moving to VoLTE this year and if so why wouldn't the latest phone support it and will there be a software update later to add the ability or has Verizon done the usual thing and screwed their customers by not making it capable of future needs on their horizon.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Probably not an update since it isn't in the fcc filing. Verizon could file again, but not likely. On the s4, the fcc filing mentioned b4 support even though it wasn't officially available until an update months after release.
Verizon won't sunset cdma until 2021 at the earliest anyway, so you should be fine unless you plan to keep your phone until that time.
ParkerAdams
