08-27-2014 08:55 PM
52 123
tools
  1. philliplavelle's Avatar
    Hi All,
    Just throwing this one out there but has anybody noticed the battery on their new S5 is not as great as the reviews all believe?
    I got mine on Thursday morning in Switzerland. It's the European model - and I brought it home to the UK.
    Charged it up fully, then let it discharge which took about 15 hours (though eight of those were in bed). Then yesterday, I charged it from 2% up to 100% at about 1pm. It was down to 20% by 10pm. Obviously, I'm using it a fair bit but no more than the other reviewers seem to imply.
    I have it linked to my Gear 2 Neo and wonder if that's the cause. But I can't see how it would be as GSAM reckons Bluetooth is low usage and also my friend is using his connected to the Gear 2 and tells me yesterday, he had 90 mins of Netflix, Facebook and general playing before he got down to 90%. GSAM tells me that the kernel is the biggest user.
    I vaguely seem to remember the S3 having a similar battery drain at first and not being sure what it was and it settled down eventually - but I'd be interested to hear your thoughts and experiences. By the way, I have Power Saving ON here too!
    As a guide, it is now down to 93% after about an hour off charge with the screen having barely been on.
    Attached Thumbnails Galaxy S5 battery issues already?-screenshot_2014-04-12-07-13-25.jpg   Galaxy S5 battery issues already?-screenshot_2014-04-12-07-13-53.jpg
    04-12-2014 02:35 AM
  2. msavic6's Avatar
    Your kernel usage is abnormally high and is the reason for your poor battery life.
    I would restart the phone and see how the battery life is tomorrow, if it doesn't get better I would factory reset and see how it goes from then on.
    Sent from my SGH-I337M using Tapatalk
    04-12-2014 03:08 AM
  3. philliplavelle's Avatar
    Hi. Yeah I figure that was what was causing it. Will restart. Phone took me hours to completely set up so want to apps factory reset if at all possible
    Sent from my SM-G900F using Tapatalk
    04-12-2014 04:11 AM
  4. philliplavelle's Avatar
    It definitely appears to be my kernel that's doing it - but what? And how can I stop? See attached screenshots I just took.. Hope someone can help. I've restarted it like msavic6 suggested and am just charging it back up to 100% again to see what that does..
    Attached Thumbnails Galaxy S5 battery issues already?-screenshot_2014-04-12-09-44-22.jpg   Galaxy S5 battery issues already?-screenshot_2014-04-12-09-44-18.jpg   Galaxy S5 battery issues already?-screenshot_2014-04-12-09-42-23.jpg   Galaxy S5 battery issues already?-screenshot_2014-04-12-09-42-30.jpg   Galaxy S5 battery issues already?-screenshot_2014-04-12-09-42-35.jpg
    Galaxy S5 battery issues already?-screenshot_2014-04-12-09-42-45.jpg   Galaxy S5 battery issues already?-screenshot_2014-04-12-09-42-49.jpg   Galaxy S5 battery issues already?-screenshot_2014-04-12-09-42-58.jpg   Galaxy S5 battery issues already?-screenshot_2014-04-12-09-43-03.jpg   Galaxy S5 battery issues already?-screenshot_2014-04-12-09-43-12.jpg
    Galaxy S5 battery issues already?-screenshot_2014-04-12-09-43-25.jpg   Galaxy S5 battery issues already?-screenshot_2014-04-12-09-43-30.jpg   Galaxy S5 battery issues already?-screenshot_2014-04-12-09-43-33.jpg
    04-12-2014 05:28 AM
  5. xmostwanted559x's Avatar
    Whats kernal supposed to show
    04-12-2014 06:40 AM
  6. philliplavelle's Avatar
    I think it's meant to be much lower than that
    04-12-2014 06:45 AM
  7. killianb's Avatar
    I'm having the same problem. Battery life was okay — nothing special — during the first few days, but it has gradually gotten worse, and “Android OS” is the issue, according to the battery stats. Today I took my phone off the charger at 8 a.m., and four hours later, it's down to 59%. I've listened to Audible for an hour (with the screen off), sent a few messages in WhatsApp, and took three pictures. That's about it.
    I can't work out what's causing the drain. I've disabled things like Dropbox camera upload and Google+ Auto-Backup, turned off always-on Wi-Fi, and even killed Google Now. But none of it appears to be making any difference.
    04-17-2014 07:07 AM
  8. philliplavelle's Avatar
    I'm reading a lot about people enabling ART in the developer options. Does that seem to work for you guys in terms of battery life or is that placebo?
    04-18-2014 03:03 AM
  9. AJnATL's Avatar
    I've done research and I can't find anything. Mine says Android Kernel is taking up the majority of my battery. More specifically the "Combined App Wakeclocks".
    04-18-2014 05:58 AM
  10. atishc's Avatar
    I was having major battery issues early on, and they were fixed by toggling off "location" in the quick settings. (I think it was trying to find me using GPS in my concrete work complex.) I have turned my location settings to WiFi and network today so I will see if the battery is as good as when I turned location off completely.
    04-18-2014 06:27 AM
  11. sirmaru's Avatar
    Kernal usage would be very high if the S5 is being stored and not used for any functions. If you are doing that, either turn off the power entirely by holding the power button for 60 seconds or use Ultra High Power Saving Mode where one can only make and receive calls and make and receive messages.
    The battery can last 12 days in Ultra Power Saving Mode from a full charge as displayed on the screen. I charged mine last night and it dropped from 100% to 97% overnight. My Kernal (Android OS) used 54.7% since no other functions were operative. The Screen used 42.9% for the same reason since it only drew power when I turned it on just now.
    04-18-2014 07:19 AM
  12. JJM1975's Avatar
    I turned off location services and it fixed it for me. There has to be some sort of bug in location services. I had it only set for GPS but even that was enough to really drain the battery.
    04-19-2014 07:49 AM
  13. dwd3885's Avatar
    This is overnight. Dropped 20% in 5 hours what gives?
    04-19-2014 07:51 AM
  14. Diredumalde's Avatar
    For the first week my battery lasted for days! I would charge it, say, Monday night before going to bed using the wall charger (which seems to charge must faster than my PC) and the phone would last through constant usage until Wednesday afternoon. Now just the last couple of days my phone is not even lasting a few hours! Just last night I went to bed at 57% and when I woke up 3 hours late I realized my phone died approx 5 hours after I went to sleep. How is that even possible?!
    I haven't changed any settings and I'm not running any new apps. My battery usage says 80% Android System.
    04-27-2014 01:59 PM
  15. shannonc21's Avatar
    I too am having a similar issue. I got the phone Friday and it lasted until Monday, it was great. Then I charged it yesterday and I noticed with in a few hours without using it at all it was down to 64%. Went to sleep at midnight and when I got up it was down to 28%. I looked in battery and this is what I saw. Does not seem right, How can I fix this. I already turned the phone off and on.
    Attached Thumbnails Galaxy S5 battery issues already?-screenshot_2014-04-29-10-24-03.jpg
    GWaLL13 likes this.
    04-29-2014 12:00 PM
  16. peteypab2133's Avatar
    I got 2 days out of mine
    04-29-2014 12:05 PM
  17. GWaLL13's Avatar
    I've been having the same issue. At first is was quick connect that was causing it and made it drop from 30% to 1% while I was asleep, I disabled that and now Android OS is the cause for the battery drain while I sleep. I have all programs closed, blocking mode on and it's still draining like a beast.
    -via Android Central App on GWaLL's S5
    04-30-2014 12:56 PM
  18. sirmaru's Avatar
    Turn on Ultra Power Savings when you sleep. That will turn off ALL apps but 6. Hopefully, when you wake and turn off Ultra Power Savings things will work properly.
    04-30-2014 03:34 PM
  19. Aurora Ramirez's Avatar
    I just got my phone on Thursday evening. I am not a heavy user. and the battery life stinks. They sold me this under the pretense that the battery would last 19 hours which meant to me I would not have to charge it but a few times a week. I have tweaked everything I can to make setting use less battery and the issue persists. my OS is taking over everything and Sprint is not being very helpful.
    05-04-2014 09:35 AM
  20. Sandra Posluszny's Avatar
    Hi! I'm from Poland and my English isn't good, but I need a piece of advice from you, because Polish Android Forum didn't help me.
    I've had my S5 for 15 days. At the beginning, its battery life was amazing! It was enough for 2,5 days or for 1,5 days when I used it strongly.
    Since last Wednesday, it drains very fast. Yesterday evening, I disconnected S5 from the wall socted, it was fully charged. This morning (I guess 10h later), it was only 47%.
    WiFi, bluetooth, GPS, all location's service etc was turned off. Before I went to the bed, I turned off all apps. I always turn on battery saving mode. I'd installed Cut the Rope 2, Evernote, Last Epress, Messenger, Nicole, Simpsong, Smash Hit, Wind-up Knight 2, but I guess they aren't the source of battery problem, because I've them also on my tablet for a long time and its battery's enough for few days. But maybe you think that they are problematic...? All apps are updated.
    Kernel used 53%, Android OS 11%.Espacially for solving battery problem, I didn't use my S5, it was just laying on the desk. But it still drains quite fast.
    Yesterday I installed DS Battery Saver and I set strong profile. But it didn't help. Maybe it's just because smartphones don't like to being unused? I also installed Greenify and I frozen few apps. CPU Spy tells: 47% - 300 MHz. Deep sleep just 24%. Total state time: almost 71h. Wakelock detector: active - 75 %. Statistic for 70h. I can't check which apps are using CPU, because I don't have ROOT access. Do you have any idea?
    05-04-2014 12:37 PM
  21. mobilecrackers's Avatar
    maybe this will help you
    decrease the brightness
    turn on the power saver option
    disable auto synchronization
    uninstall the unwanted applications
    I am using galaxy note which will not live for 1 day, due to large screen
    Ready to help you
    05-04-2014 12:45 PM
  22. Sandra Posluszny's Avatar
    I did it, but it doesn't help. What do you mean by "unwanted applications"?
    Maybe I just should use it more frequently. It's new battery, so that should be better in some time. Hm.... I don't know what to do about this.But I think it isn't normal that it's getting worse.
    05-04-2014 12:54 PM
  23. mobilecrackers's Avatar
    Unwanted applications means the apps that you are not using which you have downloaded from market
    I think this might be the battery problem, buy a new one
    Ready to help you
    05-04-2014 01:18 PM
  24. rdandy5875's Avatar
    I noticed I have to give the phone a restart after charging or I will get high battery drain, seems from the OS but a restart isn't too inconvenient so I haven't looked into it further....After the restart it's great.
    05-04-2014 10:52 PM
  25. phatboy29m's Avatar
    Last night I turned on the ultra power savings mode when I sent to sleep. At that point I had 82% battery left. I woke up about 6 and a half hours later and I had 46% battery left. This was with the phone on ULTRA POWER SAVINGS MODE...I went into the battery app and Android OS and Android System were both pushing 25% a piece with the screen coming in at 21%. How is this even possible? It's gotta be a huge glitch in the software.
    tonyr6 likes this.
    05-04-2014 11:16 PM
52 123
  1. note 3 gps issues....still?
    By acshaw80 in forum AT&T Samsung Galaxy Note 3
    Last Post: 08-30-2015, 09:53 PM
  2. Galaxy Note 10.1: Battery life way short of the suggested 9 hours
    By Closingracer in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 09-15-2014, 10:29 AM
  3. Replies: 5
    Last Post: 04-12-2014, 10:02 PM
  4. Firmware Upgrade Already
    By sjaduae in forum Samsung Galaxy S5
    Last Post: 04-12-2014, 02:47 AM
  5. Verizon disables PayPal fingerprint payments on Galaxy S5
    By smooth4lyfe in forum Samsung Galaxy S5
    Last Post: 04-12-2014, 01:32 AM
