Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By _Zguy__
    Default Battery Problems
    Just switched from the HTC One to Galaxy 5 yesterday. Upon setting it up, loved it; screen looks great, easy to type on keyboard, etc.
    It seems that the battery drains really quick - real quick! With the first HTC One (M7), had no problems with battery at all. I tried restarting the device twice, but still having battery issues. For example the phone was fully charged before I went to bed and then when I woke up 6 hours later it was already down to 67% with it being not used. What could be going on? Not an expert user with settings so any help would be appreciated before I decide I'm going to go back and just get the new HTC One. Thanks!
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,711 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Battery Problems
    Welcome to the forums.
    Keep in mind the battery will need 4 or 5 charge cycles to get into the swing of things.
    Quote Originally Posted by Golfdriver97 View Post
    Thanks for the welcome! Do I need to let the battery drain completely that many times before charging?
  4. #4
    Quote Originally Posted by li33gwm View Post
    thats really just a myth. modern lithium batteries dont need to be power cycled to "hold charge". they'll love the juice whenever you give it and work hard when its not charging. i guarantee after a couple days of normal use and charging youll see it acting normal or as expected.
    like most of us you might also be tinkering quite a bit and im sure that doesnt help. be mindful of all the apps you have running in the background
  5. #5
    Posts
    Global Posts
    32,711 Global Posts
    Carrier
    You don't need to completely drain batteries anymore. But the battery does need a few charge cycles to get into a rhythm.
    Thanks for the reply again. In terms of apps running in the background, how do I know what is running so that I can turn some of them off? Here's what my battery settings says is happening:
    Here's what is says for Battery Settings:
    55% - Not Charging
    10h 49m on battery
    Android System - 19%
    HD Widgets - 14%
    Google Search 12%
    Android OS - 11%
    Screen - 9%
    Cell Standby - 6%
    Android Core Apps - 6%
    WiFi - 4%
    Device Idle - 4%
  7. #7
    sirmaru's Avatar
    Posts
    Global Posts
    265 Global Posts
    Turn off WiFi, GPS (Location Based Services) when not in use.
  8. #8
    gtg465x's Avatar
    Posts
    Global Posts
    441 Global Posts
    Quote Originally Posted by sirmaru View Post
    Those use a negligible amount of battery when they're on but not in use. No need to turn them off.
  9. #9
    Considering you just got the phone it probably still is doing a lot of background syncing all your Google services, should be fine once all that is done
    GeekNews likes this.
  1. problem with Google account
    By bears12th in forum Samsung Galaxy S5
    Last Post: 08-08-2015, 06:54 PM
  2. Galaxy Note 10.1: Battery life way short of the suggested 9 hours
    By Closingracer in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 09-15-2014, 10:29 AM
  3. Galaxy S5 battery issues already?
    By philliplavelle in forum Samsung Galaxy S5
    Last Post: 08-27-2014, 08:55 PM
  4. Problems with the new update?????
    By Nychotxxx in forum Samsung Galaxy Note Pro 12.2
    Last Post: 04-12-2014, 09:30 PM
  5. Proxy problem with wifi hotspot
    By anksandroid in forum Moto G (2013)
    Last Post: 04-12-2014, 07:02 AM
