1. uwbadger2010's Avatar
    Hey guys, Im on my first day with the gs5 and am noticing that MEDIA is using a considerable amount of CPU time. its not keeping the phone awake but im 61% at 3hrs 51min off batt with 1hr 49min screen on and MEDIA using 1h 3min only keeping phone awake 8min 56sec.
    Any suggestions or ideas?
    04-14-2014 11:55 AM
  2. NismoZ's Avatar
    If you have an MicroSD card in there, the media service on the phone may be cycling through your songs or pictures and is stuck on something. I'd backup the stuff on your card, then format it with exFAT, then try it again and see if that fixes it.
    04-14-2014 12:16 PM
  3. uwbadger2010's Avatar
    thats what i was thinking. if i export my contacts to my usb phone storage i will not lose them correct?....and whats the best way to format the card or how is that done? via computer or phone? i dont have an adapter for my computer is why im asking
    04-14-2014 12:20 PM
  4. NismoZ's Avatar
    Well, you should have google contacts, correct? If so, they are backed up on google, so not to worry. If not, I am not sure what contacts you have stored on the MicroSD card... I took the card out, and formatted in my computer, but I had a MicroSD reader. You should be ok to format it in the phone settings.
    04-14-2014 12:58 PM
  5. uwbadger2010's Avatar
    k and yes i forgot about the google sync. ill try on the phone. thanks for the help. ill post back on the results prob later today. so far the battery is still impressive at about 2.5hrs screen on at 50%
    04-14-2014 01:02 PM
  6. NismoZ's Avatar
    The battery is VERY impressive. Unplugged for 48 hours here and on 55%!
    04-14-2014 01:27 PM
  7. Chris Abbott's Avatar
    lol wut How much screen time?
    04-14-2014 01:29 PM
  8. NismoZ's Avatar
    2h27m, not a heavy user by any means, but this is awesome...
    04-14-2014 01:38 PM
  9. uwbadger2010's Avatar
    so i pulled the card and restarted and still runs. by pulling the card should it not stop the process? the data seems to be increasing like something is downloading in the background. its up to 65 mb now. any ideas?
    04-14-2014 03:10 PM
  10. NismoZ's Avatar
    Well, that's the only one I have heard, but you could go through these:
    https://www.google.com/#q=media+cpu+android
    04-14-2014 03:25 PM
  11. uwbadger2010's Avatar
    problem solved. SAMSUNG LINK was causing the cpu and battery drain. got it on the charger now but looks like that solved it. will update for sure.
    04-14-2014 05:48 PM
  12. sirmaru's Avatar
    You can use GSam Battery Monitor to identify unruly apps.
    04-14-2014 06:30 PM
  13. uwbadger2010's Avatar
    samsung link was in fact the problem. turned off and battery is stellar now. i did use gsm battery monitor which worked great. would def recommend it to anyone with battery draining apps or processes. thanks for all the help guys
    04-15-2014 03:43 PM
  14. ddaniel87's Avatar
    I have posted this elsewhere, but I can't get more than a few hours on a charge, and DCMProvider is using it all. Now up to 80%. Reset, and still doing it. I have no idea what this app is.
    me
    04-15-2014 09:34 PM
  15. Fillyo's Avatar
    Don't even have dcmprovider, is that from a downloaded app?
    Posted via Android Central App on my S5
    04-16-2014 11:28 PM
  16. ddaniel87's Avatar
    It's been there since I bought it. No apps but stock on t mobile
    me
    04-16-2014 11:55 PM
  17. uwbadger2010's Avatar
    i replied previously to your thread and i believe it is not the dcmprovider. try turning off samsung link and see if that fixes it. they are both linked to a media process that is running.
    04-17-2014 02:58 PM
  18. uwbadger2010's Avatar
    even if it shows up on gsm batt monitor i would try samsung link first. it doesnt seem right but cant hurt as i know those two run a media process in the background. my dcmprovider is 0 since i turned link off
    04-17-2014 03:00 PM
  19. ddaniel87's Avatar
    Link is off. Still going
    04-17-2014 06:12 PM
  20. paridge's Avatar
    You might want to try Play Newsstand settings. If download while charging only isn't checked, it'll keep refreshing in the background. You should also check the settings on any news & social media apps, as well as email.
    Sent from my Nexus 7 using AC Forums mobile app
    04-17-2014 08:30 PM
  21. uwbadger2010's Avatar
    agree. id try turning off all bloatware.
    04-17-2014 09:52 PM
  22. martinfg2's Avatar
    I recently purchased a GS5, and discovered that every time I used the Gallery, DCMProvider and Downloads processes (as displayed using OSMonitor) would use the CPU for several minutes. However, there is an easy solution: open Gallery, click the top right "settings" icon (looks like 3 vertical dots), select Content, then deselect Picasa (now only "Content in device" should be checked). You might need to reboot or let DCMProvider finish doing whatever it is doing, but after that you should be able to use the Gallery app or camera app without having your phone eat CPU.
    iseeangelsMickey likes this.
    08-02-2014 04:15 AM
  1. Amazed by the battery...
    By bucketheadmn in forum HTC One M8
    Last Post: 04-26-2014, 03:32 PM
  2. Galaxy S5 replacement batteries
    By melbay in forum Samsung Galaxy S5
    Last Post: 04-19-2014, 12:20 PM
  3. M8 Battery vs Droid Maxx Battery
    By Emperor in forum HTC One M8
    Last Post: 04-14-2014, 06:57 PM
  4. LG G2: Battery Issue
    By Goldschmidt in forum LG G2
    Last Post: 04-14-2014, 08:50 AM
  5. Got two weeks battery life on my note 12.2
    By thegame161 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 04-14-2014, 02:35 AM
