1. Zendarzwei's Avatar
    Is there any benefit with using the stock cable over a normal micro usb cable?
    04-16-2014 04:32 PM
  2. ItsMeMandi's Avatar
    I was wondering the same thing. It isn't the easiest thing to plug in -- I have to actually pay attention when I do it and I feel like I'm going to break a pin one of these days.
    04-16-2014 04:37 PM
  3. bogdaryl's Avatar
    I talked to a guy at the Samsung store or whatever you call it inside Best Buy and he said the new cable provides a faster charge ( I've checked and it's been true so far it's provided about a 35 to 40% faster charge rate than the standard micro usb) and a faster data exchange rate as well. Haven't jtested that just yet.
    t
    04-16-2014 04:43 PM
  4. Zacharyw70's Avatar
    I believe it charges the phone faster similar to how the Lightning cable works for the Iphone 5 and above. Also faster data transfer if you hook it into a USB 3.0 port on your computer.
    04-16-2014 04:46 PM
  5. bespinct's Avatar
    The quick charging has to do with the Snapdragon fast charging feature, not the USB 3 cable. If I use the cable from my LG G2, it charges just as fast with micro USB.
    04-16-2014 07:11 PM
  6. psp1232171's Avatar
    Speeeeed. Enjoy
    04-16-2014 07:28 PM
  7. Jaycemiskel's Avatar
    It's only faster when you hook it up to a computer with USB 3.0, otherwise it's the same .
    Sent from my GT-N5110 using Tapatalk
    04-16-2014 08:47 PM
  1. Search only contacts with phone number?
    By Hadas N in forum Samsung Galaxy S5
    Last Post: 02-28-2015, 05:02 AM
  2. How to update Android 4.0.4 to 4.2 in SoftwinnerEvb
    By King Kumar in forum Android 4.0 Ice Cream Sandwich
    Last Post: 05-14-2014, 09:24 AM
  3. Buy phones at full price at any ATT store.
    By garment69 in forum General News & Discussion
    Last Post: 04-18-2014, 03:29 PM
  4. upgrade to jelly bean
    By Bodasefus in forum Samsung Galaxy Note 10.1
    Last Post: 04-18-2014, 11:31 AM
  5. Alarm clock volume resets itself to a low volume
    By ChrisX23 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-17-2014, 01:26 PM
