1. Harvey Williams's Avatar
    Hey guys,
    S5 battery has been dying over night when falling asleep with ~75% battery. Thoughts?
    Attached Thumbnails Battery takes a dive and dies over night-screenshot_2014-04-17-09-56-05.jpg
    04-17-2014 12:03 PM
  2. Masum56k's Avatar
    Strange. Never happen this to me.
    May be, many apps were running in background..
    Sent from my SM-G900H using AC Forums mobile app
    04-17-2014 12:07 PM
  3. hardrocker89's Avatar
    Seems like there may be an app in the background killing things. Might try using gsam battery and it will show you what's eating things up!
    Sent from my SM-G900P using Tapatalk
    04-17-2014 12:08 PM
  4. Harvey Williams's Avatar
    Thanks for the help I checked it out and its just the Android OS?
    Attached Thumbnails Battery takes a dive and dies over night-screenshot_2014-04-17-10-15-19.jpg
    04-17-2014 12:19 PM
  5. finndo77's Avatar
    both mine and my wife's S5 (only had for 5 days) died last night, mine was at 100% and I played a game for 25 minutes then turned the screen off and went to bed. I woke up a little early today and found it was off and completely dead. when my wife got up, hers was dead too. she full charged it last night, then unplugged and went to sleep. When it came back on and I checked the battery stats it only showed the last 5 minutes after I turned it back on... and had no history. Nothing seemed wrong on the phone.
    04-25-2014 08:18 AM
  6. Almeuit's Avatar
    Does a reboot help? There is definitely something waking your phone up a ton that is causing the drop.
    Sent from my T-Mobile Note 3 using AC Forums.
    04-25-2014 09:26 AM
  7. Golfdriver97's Avatar
    I know there has been a rash of excessive battery drains on the S5 lately. Everyone is still trying to figure out what may be the exact cause. Two of the possible causes have been Location reporting, and Samsung Link.
    04-25-2014 09:33 AM
  8. joehp1's Avatar
    I have been having the same issue recently. It seems to be Google+. Every time in turn on location services, this kicks in and drains my battery something like 10% per hour. I uninstalled the app, but it keeps asking me to update it in Google Play store. Anyone know how to turn this darn thing off? Just started having this issue the last day or so. Thanks!
    04-25-2014 10:16 AM
  9. Golfdriver97's Avatar
    Have you disabled it in settings>application manager?
    From a Kang Nexus 5 using the AC forums app
    04-25-2014 10:28 AM
  10. joehp1's Avatar
    Tried force stop, but nothing happened!
    04-25-2014 10:30 AM
  11. finndo77's Avatar
    I didn't install anything new in the last 36 hours, and have not had any issues before with over night battery drain, was just weird both mine and my wife's did it the same night... #1 battery use is always screen...
    04-25-2014 11:00 AM
  12. surf1's Avatar
    you have to to go in application manager, the app, clear updates and turn off to disable any of the bloat or things you don't want.
    04-25-2014 11:02 AM
  13. sirmaru's Avatar
    When sleeping at night, ALWAYS turn on Ultra Power Savings. My battery only drops 1% over night with that feature running.
    Also, go to Application Manager and uninstall or turn off unruly apps. Keep Bluetooth turned off unless where needed as in one's car.
    I disabled but could not remove the S-Health App since it was always spinning into my screen. I suspect that may be the big battery drainer.
    04-25-2014 11:38 AM
  14. Raoul Ramsaran's Avatar
    I have the same issue with mine, i did upgrade to lollipop, and the battery does drain quickly when i'm using it, but not fast enough to drop from 90 to 0 in just 7 hours while being asleep. Does anyone know how to fix this?
    08-04-2015 09:04 AM
  1. HTC M8 Led and Loose Button
    By nyyankees8175 in forum HTC One M8
    Last Post: 08-14-2014, 12:42 AM
  2. Battery Guru
    By BrandonC in forum Samsung Galaxy S4
    Last Post: 04-20-2014, 04:39 AM
  3. GSam Battery Monitor
    By sirmaru in forum Samsung Galaxy S5
    Last Post: 04-18-2014, 01:56 AM
  4. S5 takes a while to find LTE service
    By jordo487 in forum Samsung Galaxy S5
    Last Post: 04-17-2014, 12:47 PM
  5. S5 replacement battery
    By Milos1977 in forum Samsung Galaxy S5
    Last Post: 04-17-2014, 12:40 PM
