Re: Android System tanking my battery life!
I can tell you I returned one S5 and the next one is the same thing so there's that.
There's nothing wrong with the devices, like I've mentioned before, since kit Kat my s4 began with this, before that, Screen was always sbowing 60 to 65 % , the same day of the update it began having the Android system at the top, I noticed some decrease on battery but it maybe related to other things that I never adjusted, now fast forwarding to s5, it came with kit Kat so there's no way on knowing how could it be with out it, but even like this, my screen on time are insane, for the past 3 days after making all my normal adjustments, I'm averaging 5.5 - 6 screen on hours, with lte, wifi and Bluetooth for my gear 2 neo all the time. Today, I'm almost at 7 hours of screen on time, and it was unplugged last night at 10pm.
If you want to see what I'm saying here, just download Gsam Battery app and you will see that it shows threw normal usage we all Galaxy Users were used to before kit kat, so I'm guessing that something changed with kit Kat that caused issue with the built in battery usage app on the galaxies.
