1. Jason Grosser's Avatar
    So it doesn't look like the S5 supports USB audio out.. Does anyone know if this is a hardware issue?... or could it be amended with a software update in the future?
    or are there any apps or widgets that can get it working?
    thx
    04-21-2014 07:59 PM
  2. Lynx's Avatar
    thx
    Are you talking about in your car?
    04-21-2014 08:19 PM
  3. Jason Grosser's Avatar
    Yes
    04-26-2014 03:58 PM
  4. Lynx's Avatar
    Yes
    This went away with Android 3.0.
    Sent from my SM-G900V using Tapatalk
    04-26-2014 03:59 PM
  5. displacedtexan's Avatar
    False.... It's just that it's not supported by ROMs.
    It will take a custom ROM (that doesn't exist for the phone)...
    But it works great for the first gen Nexus 7, so it's still technically possible.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    04-26-2014 10:51 PM
  6. Lynx's Avatar
    Not false. In Android 3.0 they switched to MTP, there are only a handful of cars that will support this. Most manufacturers decided to use Bluetooth only instead.
    04-26-2014 11:00 PM
  7. displacedtexan's Avatar
    So all the people running USB audio out on the Nexus 7 are making it up?
    04-26-2014 11:03 PM
  8. RemyL75's Avatar
    If Audio out went away with Android 3.0, then the Galaxy S3, S4, Note 2 and Note 3 all run a lower version of Android lol
    Starting with the Galaxy S5, the version of Android 4.4.2 that Samsung uses removed most of the options in the "Accessory" section in settings. The missing options are what governed sound being heard through a Dock connection (USB). I proved this when i installed a custom ROM on the Note 3 that is a nearly complete direct port of the Stock ROM for the S5. on other ROMs that I have used (that aren't based on Stock S5), the options are intact. If i find a solution, I will post it here. I really like the new ROM, but I cannot use my iBolt dock now because of the missing options.
    07-04-2014 06:29 PM
  9. aeturbo's Avatar
    Has anyone found a fix for this? I think some people confuse the issue. Not talking about a usb connection where files can be seen by a device, but an actual usb analog audio output. So as not needing to use 2 cables, usb to charge, 1/8" cable for audio. I hate having 2 cables, and having a "line-out" audio connection is much better. Can't believe Samsung got rid of this!
    01-28-2015 10:59 AM
  1. Copy Titanium Backup files to PC via USB
    By alexondrums in forum Moto G (2013)
    Last Post: 08-21-2016, 07:55 AM
  2. Replies: 4
    Last Post: 04-29-2014, 04:32 PM
  3. How Do You Get The Sim Card Out Of This Phone?
    By PsychDoc in forum Samsung Galaxy S5
    Last Post: 04-21-2014, 11:07 AM
  4. Enable usb debugging mode from adb under clockworkmode "Broken digitizer"
    By ThElitEyeS in forum General News & Discussion
    Last Post: 04-20-2014, 11:25 PM
  5. Samsung Galaxy S4 Audio Problems When Switching Between Apps
    By mccormit095 in forum Samsung Galaxy S4
    Last Post: 04-20-2014, 06:13 PM
